Home > Maintenance & Mods (L322) > Tow bar pics
hughjayteens
2005 Range Rover Vogue Td6 Java Black
Tow bar pics
Hi All,
I want to fit a towbar to allow me to carry 3 bikes and a dog! Looking into it, even the drop plate ones are easy to remove and I'm happy to keep it in the shed when not in use but what do the various types look like when fitted as in reality I would probably end up leaving it on due to the hassle factor!
Anyone got any pics of the various types?
Cheers
Chris
Post #17778 4th May 2010 11:58am
this is the removable one:
 Discovery 4 HSE
Post #17782 4th May 2010 12:45pm
dan_uk_1984
There are two types of tow bar, but there is also a LR bike rack that slots directly into the square hole:
Post #17783 4th May 2010 12:47pm
hughjayteens
Looking at the removable one, when it is removed, there is still quite a chunk of metal visible below the bumper? Is there a big difference in quality between a genuine LR one and a decent brand such as Brink or similar?
Post #17784 4th May 2010 1:01pm
dan_uk_1984
I made my own...
Post #17790 4th May 2010 2:36pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
dan_uk_1984 wrote:
Sorry to hijack your thread hughjayteens
dan_uk_1984 you are a star Smile
I have been trying to work out what pieces of the towbar I have currently installed on my car from the previous owner - and what bits I need I think
Do you know if the cross member (Part no 17D826A ) is available from LR on its own with out the chassis arms?(I assume the two different styles shown for the chassis are for different rear bumper types)
I already have both parts that attach to the chassis (Part no's 17D826B & 17D826C) - Is this standard equipment on a 2008 TDV8 or does it mean it used to have a tow bar fitted at some time?
Only want a tow bar to fit a substanial bike rack (not for towing trailers etc.)
Any idea's Question
Post #17818 4th May 2010 6:40pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
You could always stick 1 of these into the square hole left:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...MEWAX%3AIT
Post #17824 4th May 2010 7:12pm
GKP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Cairns Blue
Yes, part number 17D826A is available as seperate part - but it's age specific to accommodate the differing exhaust mounts. (Essentially either a BMW engine or Jag era)
The other two parts (17D826B and 17D826C) are fitted as standard but are binned when you fit the towbar armature.
I use the 19D520B hitch and have fitted a demountable rack which sandwiches onto the two towball bolts like this one:
 Not sure you should be reading this bit.
Post #17843 4th May 2010 9:53pm
Andy
Ive just bought a Thule 2 bike carrier that mounts onto the tow ball. See my pic:
http://www.fullfatrr.com/forum/topic805.html?highlight=cycle+rack 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #17882 5th May 2010 8:10pm
Martin
Site Admin
Bear in mind that 17D826x aren't the part numbers, they are the picture numbers on the parts catalogue.
Westfalia is the supplier to LR for the FFRR Smile
Edited for correct supplier Embarassed
Post #17883 5th May 2010 8:16pm
hughjayteens
Noddy - can you open the tailgate OK when it is in the tilted position? A 3 bike version of that is what I had in mind.
Post #17886 5th May 2010 8:41pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
I have the same thule bike carrier and it fits well and does allow me to open the lower tailgate when tilted. It is a little tight however so make sure you have it mounted square on the towball.
It shouldn't really matter whether you have the 2 or 3 bike variant as the distance from the rear of the vehicle remains the same. I was pleasantly surprised at how accessible the boot is with the carrier fitted.
That towequipe price is the best that I found for a new one, although i got lucky and bought an unwanted gift for £30!
Steve
Post #17889 5th May 2010 9:17pm
