![]() | Home > Maintenance & Mods (L322) > Tow bar pics |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6380 ![]() ![]() |
this is the removable one:
There are two types of tow bar, but there is also a LR bike rack that slots directly into the square hole:
hughjayteens Member Since: 21 Mar 2010 Location: South East Posts: 63 ![]() ![]() |
Looking at the removable one, when it is removed, there is still quite a chunk of metal visible below the bumper? Is there a big difference in quality between a genuine LR one and a decent brand such as Brink or similar? |
I made my own... |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
Sorry to hijack your thread hughjayteens dan_uk_1984 you are a star ![]() I have been trying to work out what pieces of the towbar I have currently installed on my car from the previous owner - and what bits I need I think Do you know if the cross member (Part no 17D826A ) is available from LR on its own with out the chassis arms?(I assume the two different styles shown for the chassis are for different rear bumper types) I already have both parts that attach to the chassis (Part no's 17D826B & 17D826C) - Is this standard equipment on a 2008 TDV8 or does it mean it used to have a tow bar fitted at some time? Only want a tow bar to fit a substanial bike rack (not for towing trailers etc.) Any idea's ![]() |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2074 ![]() ![]() ![]() |
You could always stick 1 of these into the square hole left:
GKP Member Since: 01 Aug 2009 Location: Hants Posts: 75 ![]() ![]() ![]() |
Yes, part number 17D826A is available as seperate part - but it's age specific to accommodate the differing exhaust mounts. (Essentially either a BMW engine or Jag era) The other two parts (17D826B and 17D826C) are fitted as standard but are binned when you fit the towbar armature. I use the 19D520B hitch and have fitted a demountable rack which sandwiches onto the two towball bolts like this one: |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
Ive just bought a Thule 2 bike carrier that mounts onto the tow ball. See my pic:
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Bear in mind that 17D826x aren't the part numbers, they are the picture numbers on the parts catalogue.
Noddy - can you open the tailgate OK when it is in the tilted position? A 3 bike version of that is what I had in mind. |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
I have the same thule bike carrier and it fits well and does allow me to open the lower tailgate when tilted. It is a little tight however so make sure you have it mounted square on the towball.
