Home > In Car Electronics (L322) > 07 rear door panel removal
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Does anyone know how to remove the rear door panel?
I have damaged the speaker grill, and need to remove panel to repair it.
Now tried 3 times to remove it, but just cannot get it to come off.
Post #179422 24th Mar 2013 1:18am
SATVC
United Kingdom 2004 Range Rover Vogue Td6 Java Black
If its the same as an 04
Remove the torx screws from inside door handle and the 2 on the door pocket then the 1 behind the airbag logo (this just pops off)
Lever the bottom of the door panel till it pops off. Then lift and pull out of the top clips.
Unplug all wires and your done!!
Post #179436 24th Mar 2013 9:54am
Video link in the wiki Thumbs Up
It is stiff and does feel like you are going to break something! Watch out for the spacer in the middle of the door card that can fall away. .
Post #179442 24th Mar 2013 10:28am
SFM
Ive bloody tried this 4 times now! mine is slightly different from the video, on mine there are 3 screws, and once removed, pop the fixings.. but there seems to be something in the middle of the panel holding it to the door,VERY FRUSTRATING!! should be a simple repair job, once removed.
Post #179544 24th Mar 2013 7:04pm
Lift the trim when its hanging off as its sat on a large plastic pop clip in the middle that often will not pull apart, but lifting the panel slides it out of the panel... Remember to pop it off with a trim tool and refit it to the door card before you re-install Thumbs Up
Craig Thumbs Up
Post #179584 25th Mar 2013 1:37am
SFM
Right..at last, someone who`s done one!
this is where I`ve got too, remove 3 torx screws, and begin popping panel clips, removed trim between window glass, so that I can lift panel,that`s it, bloody thing will not budge, and concerned that I`ll break somthing if I force it.
Do I need to slide a large screwdriver or similar to pop the centre clip?
Please help, this is so frustrating! If I can remove panel the repair should be simple.
Steve
Post #179706 25th Mar 2013 10:29pm
SFM
Bump!
Post #179986 27th Mar 2013 6:31pm
SATVC
Have you removed the screw in the door handle?
You say you undid 3 screws but there's 4
2 on the door pocket, 1 in the middle of the door handle and one behind the landrover logo plastic cover!
Post #180007 27th Mar 2013 8:01pm
SFM
On mine, an 07 TDV8 vogue with logic 7 sound, the panels are different from the TD6 i think.
I have removed 3 torx screws one in handle recess, one under the landrover tab, and one in the storage bit at the bottom of the door, released poppers on the sides and bottom of panel, and thats as far as I can get, seems to be held solid in the centre of the door panel,cannot lift panel upwards/downwards or any other way.
Please can someone help, as I don`t want to damage anything, but would really like to repair speaker cover, as it spoils an otherwise lovely interior.
Steve
Post #180080 28th Mar 2013 11:45am
Here is an image from the 07-10 workshop manual Wink
Seems there are three screws on view, and the one behind the LR tab. .
Post #180162 28th Mar 2013 10:54pm
Steve
You need to remove four screws in total 3 in the cars itself and the 4th is hidden behind the LandRover badge...
Post #180215 29th Mar 2013 11:25am
SFM
HOORAH!!!!!
Finally got it off, only to find its impossible to gain access to the rear of the speaker grill {mid range one]
what a p****r! thanks for your help guys, [mine did only have 3 screws, it is different to the ones shown]
Anyway, I either see if I can find a secondhand doorcard, or stick a small land rover badge over the damage.
cheers anyway
steve
Post #180338 29th Mar 2013 8:06pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I struggled with the central black clip today, took all 4 door cards off and applied copious amounts of sound deadening. Even did my lower tailgate while I was at it Smile
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #180339 29th Mar 2013 8:15pm
is not the 2007 s/c very quite anyway mr p. ... - .- -.
Post #180340 29th Mar 2013 8:16pm
TheAllSeeingPie
It's already very quiet, but I had some extra soundproofing foam left over from another project so decided to fit it. The car is amazingly quiet now, even with the bonkers exhaust on it.
Post #180610 31st Mar 2013 8:20pm
