Home > Maintenance & Mods (L322) > Question after 2006 facelift conversion
Page 1 of 3 123>
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Hi Folks,
Today I was brave enough to attempt the front facelift on my 54 vague to the 2006 front end. All went ok although I have the fogs to adjust as the bezels don't fit back on and I can't get the headlight washers to work...
But - the lights are all wired up but can anyone tell me what the silver bulb in the marked space (in red) in the image below is. I thought it was daylight running but that's a small LED in the corner. Is it sidelight..?? If so, I have no idea how to wire this one up.
 Ash
2016 SDV8 AB
Post #181576 6th Apr 2013 9:17pm
ebajema
That's your cornering light. If it is capped (like on mine), then it is unlikely to be functional. You need the adaptive light system anyway. MY 2010 5.0 SC Galway green and sand interior!!
Post #181577 6th Apr 2013 9:21pm
daveo
they are cornering lamps, they come on at low speed when turning into a drive ect but will not work with your car.. V8 facelift Range Rover Autobiography 22" wheels.
Post #181578 6th Apr 2013 9:22pm
comports
Cool - THanks both - I'm happy if its the cornering light and I know It won't work but just wanted to make sure. Ash
2016 SDV8 AB
Post #181579 6th Apr 2013 9:23pm
comports
Dave - Did you do the 2006 upgrade on yours..? Any clues on how to plumb in the washer jets for the lights.? Ash
2016 SDV8 AB
Post #181581 6th Apr 2013 9:24pm
why not wire it up to the side lights ,might look ok.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #181582 6th Apr 2013 9:24pm
daveo
comports, from memory you have to link to wires togeather behind the head lamp, let me look for the post to find out the colours, unless stan beats me to it. V8 facelift Range Rover Autobiography 22" wheels.
Post #181587 6th Apr 2013 9:48pm
daveo
Its the plug with four wires ands its the brown/black wire and the pink/grey wire dont forget it will only work with the lights on and squirts on every sixth squirt of the windscreen
Let me know how you get on V8 facelift Range Rover Autobiography 22" wheels.
Post #181588 6th Apr 2013 9:52pm
comports
Thanks Dave - I'll give it a go tomorrow but think its wired in correctly.
Do you know how it should be plumbed in though. The back of the washer bottle has 3 pumps. I pulled the plug from the far right one (as that one seemed to feed the old wash/wipe) to power the new pump, fed the outlet from the old pump to the inlet of the new pump and then onto the washer feed but nothing seems to come out.
If the old pump has no power does the water still flow through it.?
Cheers
Ash Ash
2016 SDV8 AB
Post #181589 6th Apr 2013 9:54pm
daveo
the old washer bottle does not have the hi power washer pump for the 06 headlamps but you can get away the the original headlamp washer, what you will find is the washer on the shorter hose squirts stronger but if you use one of those fish tank air pump clamps and restrict the hose you can even them out, V8 facelift Range Rover Autobiography 22" wheels.
Post #181593 6th Apr 2013 11:03pm
RR2008HSE
Thanks! Bow down I always wondered what that was and why no switches seemed to turn it on.
Post #181598 7th Apr 2013 12:40am
vnitos
South Africa 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
cornering light
will it be possible to link up the cornering light with the main beams or the fog lights
Post #181603 7th Apr 2013 5:40am
comports
Right Dave,
I'm going to try to short the two wires you mentioned above to see what happens but talk me through the wash process will you.
So Pull wiper stick towards me - windscreen washes
Push wiper stick away - rear wash wipe
What does the button on the end do as mine seems to just do front wash wipe again.
So to try the lights jets - turn on lights, pull stalk towards me and on the 6th go the lights should squirt..?
cheers Ash
2016 SDV8 AB
Post #181867 8th Apr 2013 7:02pm
comports
Calling Daveo....!
Just jumped the two wires and got a spark! No keys in ignition or lights on. Now I get all manner of dash lights and error code 32 air can bus fault and air suspension inactive.
HELP !!!
Ta Ash
2016 SDV8 AB
Post #181881 8th Apr 2013 7:54pm
comports
Semi panic over. Did the lock to lock and using IID cleared the faults and all ok again I think
Not sure I want to short the wires again just yet though until someone confirms this. There is front left light (near side) with a spare plug - 4 wires with the correct wire color combo and the off side light only has 3 wires going to it. Should these be jumped as well?
Thanks
Ash Ash
2016 SDV8 AB
Post #181884 8th Apr 2013 8:08pm
Page 1 of 3 123>
