![]() | Home > Maintenance & Mods (L322) > Question after 2006 facelift conversion |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Thanks Dave - I plan to have a good look around today to see if I can work it out. I may well start by using the old pump to see if it all works and them work out if I can swap out for the new pump.
All fixed and I need shooting please.....
Hi Mate,
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
Hi Dave,
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
Glad I found this thread - I'm just finishing off my 2006 conversion and have replaced the washer bottle and pumps with the new ones including the high pressure one - transferred over the connectors. Windscreen wash is fine - rear wash is fine but nothing on the headlamps. I will go and jump the wires mentioned a few posts back and see what happens. "On first name terms with my local Dealer......now."
Ok so I have followed the above directions and have bridged the outer two wires on the four way plug. First time you start the car and wash the windscreen I see a blast from the headlight washers |
Others can chip in here but I think I asked the exact same question. there is also a time delay on this so it will only work again after 3 (??) minutes or something like that and again only on the sixth press?
That's great to hear - many thanks for the info. "On first name terms with my local Dealer......now."
