Home > Maintenance & Mods (L322) > Question after 2006 facelift conversion |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
I am not sure if it is 'safe' to wire the cornering lamps up to come on with fogs/ side lights or dipped beams like some have suggested. I am sure I read somewhere that there have been incidences of lamp units being damaged by heat from the cornering lamps if they have been on for a longer than 'normal' time 56 TDV8 Vogue SE
8th Apr 2013 9:17pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
One washer plug has 3 wires the other has 4 its the plug with 4 wires you need
9th Apr 2013 7:51am |
Why not just plug back in your wiper motors? |
9th Apr 2013 8:05am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1652 |
Because the facelift does not have wipers - it's jets now with no room on the bumper for the wipers. Ash
9th Apr 2013 8:10am |
And thanks Johnny - I'll give that a try..! Ash
9th Apr 2013 8:12am |
Read the reply again my friend... Should think i of all people would know the wipers won't fit after facelift!!! |
9th Apr 2013 8:15am |
Hi Craig - Wasn't suggesting you didn't know but still not sure of your answer re wiper motors (Unless you mean just the motors and attach them out of the way inside the engine bay..!!)
9th Apr 2013 9:33am |
9th Apr 2013 6:55pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i will have to have a look at my one, its covered in heat shrink so i will cut it back and see, you could always jump the connection from the windscreen pump, just means it will squirt with the windscreen washers but will work the same.. V8 facelift Range Rover Autobiography 22" wheels.
9th Apr 2013 9:14pm |
Thanks Dave,
9th Apr 2013 9:18pm |
10th Apr 2013 12:48am |
Doh - Of course it is Craig - Thx for that.
10th Apr 2013 8:33pm |
12th Apr 2013 9:18pm |
Can anyone confirm if I need to use this bracket for the bumper please on the retrofit conversion.
13th Apr 2013 8:21am |
