![]() | Home > Technical (L322) > Normal run temp |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Too cold, cant remember what it should be but around 90 ish i think.
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
I've been monitoring stuff like this for a while. Mine generally runs at 96 for coolant and engine oil. |
| 666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108
Normal running temp is c. 90 degrees. I recently had the same issue, changed the main stat and egr stat to fix it.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
It depends if you have been driving or sitting still in the driveway for an hour. Diesel engines don't warm up very well when the car is not driving (as diesels, don't know about the TD6/TDV8 though, have a coolant flow that is going "around" the thermostat). MY 2010 5.0 SC Galway green and sand interior!!
| All times are GMT |
