![]() | Home > My Range Rover > New Addition |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
you dont see many that colour.....very nice. |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
At least Joe will be happy to see it ... Looking good |
| davidmg Member Since: 29 Mar 2013 Location: Nottinghamshire Posts: 63
Sometimes you have to buck the trend in colours! |
| MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182
Nice...!!!! Great color, haven't seen one of these over here yet, mostly black and grey and an occasional green but certainly not a red one... Nice...!!!! |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Nice car I suggest you paint the Exhaust Box, Tow Bar & Armature with Black Silk Spray paint. Quick & easy job. |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
David - Without getting all slushy... That is beautiful. What a lovely colour.
| Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392
lovely colour |
| BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429
Nice |
That is on the list of jobs to do, just need to find a way of getting the ball off as there is no key! |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
If you look further under, there should be a bolt - there's a 50cm square armature that looks very much like an American 2" receiver hitch. The whole tow ball assembly should slide out once the bolt is removed.
I've never really understood the FFRR system and why that upside down cup thing is there - I have the drop plate tow bar and a locking pin through the armature to remove it quickly - it looks significantly neater when removed..... like this -
Thank you Alistair. I wonder if there is a way to remove the ball bit without a key? |
| CMJ Member Since: 10 Oct 2010 Location: Lancashire Posts: 208
Happened to me. The number of the barrel doesn't apparently match up to a key - so your dealer will either have to send for a bunch of keys to try and establish which one it is (£500 deposit for keys I believe) or you can do what I did which is find the local Westfalia dealer who has their own bunch of keys. Try each one in the car park and Hey presto you are sorted. Key was only about £20 once I had found the right one ! 2013 L405 AB 4.4SDV8 Luxor/Ivory, 2007 Vogue TDV8 Epson Green/Sand, 2008 Vogue TDV8 Buckingham Blue/Sand, 2003 Vogue 4.4 LPG Epsom Green/Sage, 1998 Vogue SE 4.6 LPG Epsom Green/Cream |
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
There is a way to remove it without the key, I'll PM you but it does render the towbar a bit useless. |
