Home > Maintenance & Mods (L322) > Bike Rack for ball type tow hitch
verydisco
Hi gang.
My FF was fitted by the land Rover dealership with a removable ball type tow hook from GBW, from Germany:
http://img3.rameder.lu/assets/640x640/103190_640x640_v1.jpg
http://www.rameder.lu/en/Towbars/Tow-bar-103190-04869-1.html
This means I do not have the square "US type" receiver, therefore I may not use LR's OEM bike rack.
Do you know of an alternative (and can offer feedback - or better sell one), supporting 2 adults bikes, ideally with a swing away frame such as the OEM post 2009 accessory bike rack?
http://www.rangeroverpartsstore.co.uk/medi...500020.jpg
AS DISCUSSED HERE
http://www.fullfatrr.com/forum/post137831.html
The only aftermarket rack I could find that allows access to the back is from a russian site :
http://www.lrmoscow.ru/akssesyar-range-rov...00020.html
thanks l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #183497 18th Apr 2013 8:27am
You should be able to find a replacement "normal" towbar fitting on eBay, then you can use whatever you want for a bike rack. The square end is a standard size. Search for motorhomes or similar. .
Post #183544 18th Apr 2013 1:49pm
its 2 inches square btw.. ... - .- -.
Post #183545 18th Apr 2013 1:55pm
verydisco
I am familiar with the 2 inch US type type, but on mine, the ball hitch receiver is built in the bolt on frame, so I can not simply replace it as suggested.
I am now thinking of getting one of the ones that simply clamps to the ball* and call it a day, as there are no clamp-on dedicated for the FF.
Cheers
*(ooops that must hurt!) l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #183560 18th Apr 2013 3:28pm
There are loads that will clamp onto a swan neck tow ball - Thule & plenty of others.
If you want to tow at the same time, then try a Maxx Raxx
Post #183717 19th Apr 2013 11:17pm
No it isn't Razz
"US Type" is probably the best description as it's actually 50mm square.
I have a Jeep with a 2" square receiver and several inserts, all of which are slightly too big for the FFRR.
2" = 52mm Big Cry
Post #183718 19th Apr 2013 11:22pm
Embarassed Double post
Post #183719 19th Apr 2013 11:23pm
http://www.pfjones.co.uk/westfalia-portilo...rrier.html
The above is the westfalia bike rack which will clamp onto your ball. Have a look on amazon or ebay as well as i have seen it for a lot less. They do it in various carrying capacites. There is nothing that can't be fixed with a hammer😜😜
Post #183737 20th Apr 2013 8:19am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Alistair, can't you just angle grind it down a bit?
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #183749 20th Apr 2013 9:40am
verydisco
Thanks lads, however, the all of them do not allow to drop the tailgate unfortunately.
Cheerio l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #183774 20th Apr 2013 1:31pm
verydisco
This is what I need:
Westfalia Portilo BC60
Anyone ever used it on the FF?
http://www.pfjones.co.uk/westfalia-portilo...rrier.html l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #183775 20th Apr 2013 1:37pm
Not tried that one - one of my mates has a very similar Thule one - very heavy once the bikes are on it - dropping & raising is not a one person job.....
Holds 4 bikes really well though - I was seriously impressed as it just grips the ball
Post #183833 20th Apr 2013 8:33pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
verydisco.
GDW are a Belgian company who also have 2 sites in France. They also 'do' bike carriers -
http://www.gdwtowbars.com/index.php?/fietsendragers
look at the - Click&Go: "La crème de la crème"
I had to contact them [not for bike carriers] and they were extremely helpful
Perhaps they have something round that replaces the swan neck.
Maybe it is worth contacting them?.
Rgds
Post #183869 21st Apr 2013 8:14am
Alistair wrote:
No it isn't Razz
2" = 52mm Big Cry
Hmmm, mine was a bit tight (I bought one for an "RV" as opposed to a "motorhome" from a UK eBayer) (currently measures as 50mm though), but I just sanded down the powder coating a bit to make it fit Smile I'd call it a 2" Wink .
Post #183878 21st Apr 2013 9:39am
