![]() | Home > Technical (L322) > Off road height |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
the light should be on next to off road as that's what the car is in. You need to check that all doors and boot are closed properly or the car will not drop and the rotary switch will not do anything (although I think it should at least flash??) Ash
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Try turning the car off and on again and retry with the doors closed... |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
I just took the car out and went over 30 and it righted itself...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
i should think it hasnt been in the off road height for a while so it could have stuck up there.. ... - .- -.
Just drove the car 200 miles and lowered the car to access height and the old problem has arisen again.
RS2000CUSTOM Member Since: 25 Apr 2013 Location: The Black Country Posts: 137 ![]() ![]() ![]() |
You may want to read my previous thread on EAS "issues"
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
O2 sensor and suspension completely separate, no way connected.
I agree about dealers being part swappers.
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 ![]() ![]() ![]() |
When the air pump overheats that throws up the error message that you are getting and no lights on.
Bill, how do I get the pump ventilated? 2009 Vogue TDV8 Nara Bronze
Soz for delay, work got in the way.
Bill thanks. I wonder whether it overheated due to the car being loaded up.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
It's sometimes an indication of a pinhole in the airbag causing it to leak very slowly, but enough for the compressor to run overtime? |
STEV8 Member Since: 02 Nov 2012 Location: essex Posts: 35 ![]() ![]() ![]() |
Ditto Allseeingpie.Had similar problem myself.You need to check air-struts for leaks.Have you had any sagging on any 4 corners? If there`s a leak on any of them it will overwork the compressor, which then shuts down.Had mine done at an Indie and I think they sprayed water on all 4 -just like checking for a puncture.End result was new compressor (because I left it too long to diagnose problem,therefore knackering the compressor) and 2 x new front bags (gutted) total cost fitted £1000+.EAS problems seem fairly common with the FFRR and IMHO the less you play around with it the better. 05`V8 AUTOBIOGRAPHY |
