![]() | Home > Maintenance & Mods (L322) > Seat Foam Replacement |
I was thinking of replacing the foam in my drivers seat as the side has collapsed just slightly. I thought this was going to be a super expensive part...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35837 ![]() ![]() |
surprisingly its not that hard to strip the seat, my son replaced the occupancy sensor in my passenger seat and it went quite smoothly.... ... - .- -.
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Stan, is there any chance of a write up on how to replace the foam / sensors? I'm curious to know how to get the seat cover off so I can put a new foam in. |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Perfect timing. I have been thinking about getting my car into an upholsterer to get them to rebuild the seat. But thanks to dan_uk_1984 I have now ordered a new squab foam.
crikey this was back in 2010 and as said my son done it..i recall that the little springs were a slight problem but other than that i cant remember ,sorry.. ... - .- -. Y. O. L. O. . |
I had a look in Rave today and its all there how to dismantle the seats.
Yeah did it last night. You just need to take the side trims off and peel the leather off. Rather easy although the rings were a pig to fit back on. Seat feels a lot better but unfortunately I scratched the centre console piano black trim |
spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 ![]() |
Hi where did you get foam from and cost |
GreenBlood Member Since: 26 Feb 2013 Location: South West London, Surrey Posts: 84 ![]() ![]() ![]() |
Good to know, thanks. If you don't get stuck then you are not trying hard enough. 2012 FFRR TDV8 Westminister Gone: Def90 2.8i, Def110 2.8i Gone: RRC 2-Door and 4-Door, 2007 FFRR TDV8 Vogue Gone: Aussie Spec D1 V8, D2 V8 |
Instead of refitting the rings could cable ties be used instead?
i wouldnt have thought so , there's a lot of weight and strain on these rings/clips.. ... - .- -.
I'd recommend some hog ring pliers (around £12) so you don't have the fun I did doing it with normal pliers. Got the foam from Dan @ Duckworths |
