![]() | Home > Maintenance & Mods (L322) > FFRR. Only got it yesterday - Oil on the drive this morning. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837 ![]() ![]() ![]() |
If it was engine oil from a diesel, it would be black, so I'm not sure it is.
dirtyharry Member Since: 23 Oct 2012 Location: Ashby Magna Posts: 242 ![]() ![]() ![]() |
Could be transmission oil leaking from the cooler. I had the exact same problem last month and it was a pig of a job to fix. Need to remove the underside cover and that will probably show where the source of the leak is |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Take a look around the rocker cover as it could be leaking from the gasket? 2009 Vogue TDV8 Nara Bronze
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
Also make sure it's not just clean oil where they have been a bit careless with an oil top up/ change. I've seen that before, when my mate thought he had an oil leak, explained that he had a very small, clean oil leak. After about 15 mins of checking all the usual places, all I could see was oil from this "leak" on the side of the engine. So we cleaned the engine bay, and hey presto no more leak. |
Trev18 Member Since: 23 Apr 2013 Location: North Manchester UK Posts: 267 ![]() ![]() ![]() |
Thanks Guys... I will take a look... This morning..... Worst case scenario... Its going back to the garage for them to fix as I only got it on Friday... |
Which garage did you get it from?
Most importantly check it's not brake fluid as that is a clean oil... And that amount on the floor could have catastrophic consequences...
Update .......
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 ![]() ![]() ![]() |
It's probably the best car you'll ever own, just not the most reliable |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
Thought it sounded similar to my little joyous leaks found today:
Update 2...
That's the spirit Trev... Buying more stuff for the FF while your waiting for it being fixed... |
