![]() | Home > Maintenance & Mods (L322) > Heated seat pad |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Noooo rich, I have a 52plate vogue. And I bought a complete seat in the right colour leather for £30
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
I had my seat apart to colour change it and I dont remember it being in the leather, I changed the foam pad though and seem to remember it being almost glued to that, it all came apart and swapped over no problem [/img] One day your life will flash before your eyes......................................make sure yours is worth watching! ![]() |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
The elements are inside a foam type material and are definitely stitched in with the leather cover on earlier cars. I have a set of theses seat base elements ready to go in my seat which have been unpicked from a new cover, I'll post a picture up later. They are completely different to the later type.
The seat is very easy to remove dude, do not attempt it in the car. the seat is pretty heavy, you need to seperate the squab and backrest, if you get stuck let me know and ill try and talk you thru it but it was a while ago and ive been in a coma since then !!!!! One day your life will flash before your eyes......................................make sure yours is worth watching! ![]() |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Lol ok Johnny cheers I will now need to look out for the element... 2009 Vogue TDV8 Nara Bronze
Luckily the base is the easy part to strip down, a little tip to make life easier is the leather part is pulled under and located with metal clips, I cut these and put back together with cable ties. One day your life will flash before your eyes......................................make sure yours is worth watching!
Well today I took out the drivers seat and stripped it down ready to retrim, only to find the reason for what I was doing (heated seat not working) to be a broken connector, so soldered it all back together and repaired. Put it all back together, fixed the switch bank and not it works perfectly! So the new seat trim I bought is no longer needed lol. |
Did the light work when you pressed the button and then go off again? 2009 Vogue TDV8 Nara Bronze
yea thats what it used to do.
In that case I will check the connection.
Yep |
Which connector was the culprit mate? 2009 Vogue TDV8 Nara Bronze
it was the connector that plugged into one of the elements in the seat base |
And there are 8 connections in total? Are these all under the seat? 2009 Vogue TDV8 Nara Bronze
