![]() | Home > General > Speed restriction on TDV8? |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
The limit can easily be removed with a Faultmate and possibly an IID tool.
I think the lowering is more to do with reducing the drag on the vehicle caused by the sheer volume of air going under the vehicle and the aero affect it causes |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
the 2002-2005 pre-facelift will go down to motorway height between 65/70 mph , the 2006 onwards apparently go down at 100 mph.. ... - .- -.
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
The 2006+ do not lower - or if they do they do not indicate this fact. I have tried this on a 4.2SC, 5.0SC and 3.6TDV8.
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
The 2006+ definitely do lower and it's marginally visible on the "off-road screen" but isn't indicated as anything special. You can just see the car sitting lower on that screen (similar to access mode). This is something I'd recommend you get a passenger to check though as you should be looking ahead when you're going that fast. It raises up after you've slowed down to less than 80 for about 30 seconds. |
^^ something i'm hoping to change with some more fiddling |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
I've driven loads on the German autobahn, often in the middle of the night, and it's very rare you're able to sustain those kinds of speeds for any length of time, especially in a vehicle that takes quite a while to get there. You'd have to be nuts to go past a line of trucks doing 55mph when you're at 150mph.
My 2006 is already 20mm lower than standard across all modes to make it handle better in corners, are you saying at 100mph I'm riding AT access height-20mm? I think you will find I am not!
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626
Pre-Terrain Response:
Post-Terrain Response, pre-Adaptive Dynamics:
As for what yours does, who knows? That's why it's best not to mess with things you don't understand. Access height is, however, 40 mm lower than On-road height. |
| wslr Member Since: 04 Dec 2011 Location: Wellington, Somerset Posts: 64
Latest info from TOPIx about this. |
DMRR, what evidence do you have that the handbook is wrong on this? |
I will ignore your arrogance. My information is based on actual experience. So, in my case, it doesn't lower, and never has. Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
Sustained driving on the limiter across Germany on the way to Poland. No mode change indication occurred and the white lines didn't move lower to the wheels. Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
DMRR, i can only think that because you have lowered yours 'manually' then the ranges ecu cant lower it any more when you do go above 100 mph.. ... - .- -.
| All times are GMT |
