![]() | Home > Maintenance & Mods (L322) > Interior upgrade |
dave699 Member Since: 03 Apr 2012 Location: Redcar Posts: 457 ![]() ![]() ![]() |
Done the job today. Burr Walnut replaced with Grand Lacquer black.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3926 ![]() ![]() ![]() |
I would very much appreciate a walkthrough on getting the dash top off if you have time.
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Does the dash top need removed to get the panel above the gloveboxes out?
Lots of Youtube vids on dash removal on net. |
Supershuttle:
Open upper glovebox, remove passenger dash end, probably get away with leaving airbag switch plugged in, if your careful. Black trim from above glovebox, has one screw under passenger dash end trim, it can then be pulled out directly towards you, when your sat in the seat looking at it. ( it has two or three clips at the very top edge so pull it straight out, don't twist it upwards. ![]() Had it, loved it! 2007 Vogue SE TDV8 Stornoway Grey / Ivory Climatic Seats, RSE, AFS, Deployable steps, iPod kit. |
Thanks Dave, photo as promised showing lower dash panels wrapped and also side on centre console |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35769 ![]() ![]() |
did you do that yourself geoff ? ... - .- -.
Bellini:
I like the Carbon wrap |
If there was a hint of sarcasm or a raised eyebrow here I am playing a straight bat - yes I ![]() ![]() |
You got the side bits for the console, now that looks smart. Are they sold separately do you know? Geoff |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 ![]() ![]() ![]() |
Top Notch sir |
