Home > Technical (L322) > 4.4 TDV8 mystery radiator
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Whilst getting to know my car I came across some vents in the right front wheel arch liner. Looking through them I see what looks like a radiator. Mine is heavily clogged with dirt so plan to have my local dealer clean it out when they'll have my car in June for some other work.
My question is, does anyone know what this radiator is for? Mine being clogger I'm concerned what the potential consequences may be. 4.4 TDV8 Vogue Baltic Blue MY11
Post #191403 30th May 2013 11:43pm
Dolphinboy
Fuel burning heater? Tho that's passenger side on mine. Does RAVE cover your year and model? If so, search on here and download. Should show u exactly what it is Thumbs Up
Post #191408 31st May 2013 12:17am
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
I think it's an oil cooler for either the transmission or engine oil if I remember rightly. You definitely want to clean it, a gentle soaking with some degreaser followed by a hose down shoud be enough.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #191421 31st May 2013 8:05am
Yep, its the transmission oil cooler.
Mine had a dead bird wedged in it, the feathers basically covering the face of it! Discovery 4 HSE
Post #191422 31st May 2013 8:13am
ebajema
Have a look at this post. Once you've done the download, the workshop manual can be viewed at your leasure.
On the SC the cooler on the right hand side (UK driver side) is the engine oil cooler by the way. I haven't looked for the TDV 8, sorry.
http://www.fullfatrr.com/forum/topic17623.html MY 2010 5.0 SC Galway green and sand interior!!
Post #191424 31st May 2013 8:18am
Baron
Thanks for the info folks, I'll give it a swill out this weekend with a hosepipe. 4.4 TDV8 Vogue Baltic Blue MY11
Post #191510 1st Jun 2013 12:39am
You can pop the grille out that sits in front of it in the lower valance in seconds, then you've got access to get your hand up the front of it to clear it out.
Ebajema, it could well be the same part, maybe it's not the trans cooler?
Either way, if it's blocked it needs clearing. Discovery 4 HSE
Post #191513 1st Jun 2013 7:53am
ebajema
Just had a quick look at the workshop manual and it looks like it is the additional engine cooler. So it has coolant going through, not oil like the SC.
The transmission oil cooler is the same as for all the ZF 6HP26 boxes by the looks of it. The same one that failed on my car Sad MY 2010 5.0 SC Galway green and sand interior!!
Post #191517 1st Jun 2013 8:35am
Baron
Yes, I think that's what it is, an additional engine cooler radiator. Item 2 in this pic..
Started with a gentle clean with a hose pipe and slowly worked up to a very careful finish with a jet wash. Clean as a whistle now and no bent cooling fins. Job done and thanks for your help chaps. 4.4 TDV8 Vogue Baltic Blue MY11
Post #191562 1st Jun 2013 3:34pm
ebajema
Yep item number 2.
Well done on the cleaning !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #191599 1st Jun 2013 7:03pm
