![]() | Home > Technical (L322) > 3 beeps possibly cured ? |
I have three Venture Cams and none of them has ever beeped |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
I had the same on an old Freelander - it was a keyfob battery low warning. |
Tracker ? .
steves025uk Member Since: 24 Oct 2012 Location: London Posts: 52 ![]() ![]() ![]() |
Still have the mystery three beeps. I can stop them, by stopping the car, turning off the ignition and restarting.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
read these,
Read all the Wikis, none applicable in this case.
Have you read this post?
Thanks, but it is definitely not the clock.
any lights on the dash when the beeps start? ... - .- -.
No lights on the dashboard or error messages.
Your wifes phone is flat under the seat? |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Could it be a faulty parking sensor or maybe a loose / damaged wire on one of the sensor looms? Does the PDC light come on above the PDC switch when the beeps occur?
That sounds like a plan !!
Unlike a D3/4 the FF's PDC does not come on at slow speeds so i would say unlikely... ![]() |
