Home > Technical (L322) > 3 beeps possibly cured ?
steves025uk
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
I have had an intermittent problem with mysterious 3 continuous beeps.
No fault codes or reports.
The handbook was of no help at all.
I finally asked the wife to take the Venture Cam out while we driving along, but the beeps continued.
When I replaced the Venture Cam and 'clipped it back into the closed position' the beeps have stopped.
Could it be it was warning me the venture Cam needed recharging ?
This may be a complete coincidence, but it is something i haven't seen mentioned online or in Forums when I have searched.
It may be of help to somebody being driven crazy by constant beeping. Shocked
Post #191143 29th May 2013 10:29am
I have three Venture Cams and none of them has ever beeped Shocked 2008 MY Supercharged
Post #191146 29th May 2013 11:17am
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I had the same on an old Freelander - it was a keyfob battery low warning.
Post #191159 29th May 2013 12:20pm
Tracker ? .
Post #191163 29th May 2013 12:32pm
steves025uk
Still have the mystery three beeps. I can stop them, by stopping the car, turning off the ignition and restarting.
But, the beeps return again at seemingly random times, they seem to happen on full, or nearly full lock almost as if it is a 'tilt' switch or motion sensor ?
On a recent 120 mile trip I must have restarted the car 10 times at junctions or traffic lights.
It is sometimes preceded by a short trill of beeps which I think I have heard on starting before ?
I may have to resort to the 'stealers' as it isn't something that anybody can bear for long.
The fault check button states 'check OK'.
Any ideas ?
Post #192188 5th Jun 2013 2:45pm
read these,
http://www.fullfatrr.com/forum/topic7298.html?highlight=beeps
http://www.fullfatrr.com/forum/topic4213.html?highlight=beeps
http://www.fullfatrr.com/forum/topic1351.html?highlight=beeps ... - .- -.
Post #192189 5th Jun 2013 2:49pm
steves025uk
Read all the Wikis, none applicable in this case.
Tried changing the key fob for the spare, still did it.
I do have a Tracker fitted, but it isn't activated and seems too intermittent for that.
Is there some sort of stability warning or tilt switch on a FF ?
Looks like a trip to the main dealer for me.
I will let you know if they manage to find it.
Post #192310 6th Jun 2013 10:06am
Katash
Have you read this post?
http://www.rangerovers.net/forum/6-range-r...iving.html
Post #192312 6th Jun 2013 10:31am
steves025uk
Thanks, but it is definitely not the clock.
I drove for nearly an hour yesterday before the infernal beeps started, and then went away after 5 minutes.
I am completely baffled. Rolling Eyes
Post #192525 7th Jun 2013 10:58am
any lights on the dash when the beeps start? ... - .- -.
Post #192526 7th Jun 2013 11:01am
steves025uk
No lights on the dashboard or error messages.
It is the same tone as the front parking sensors, but the repetitive three beeps, pause three beeps etc, preceded sometimes by a trill when turning. Could there be a problem with the TPMS ? apart from the usual random visual warnings ?
Post #192664 8th Jun 2013 9:20am
Your wifes phone is flat under the seat? Rolling Eyes Laughing
Post #192667 8th Jun 2013 10:05am
Discotigger
Could it be a faulty parking sensor or maybe a loose / damaged wire on one of the sensor looms? Does the PDC light come on above the PDC switch when the beeps occur?
Try pressing the switch when the beeps occur and see what happens.
Post #192669 8th Jun 2013 10:06am
steves025uk
That sounds like a plan !!
Thanks i will try it.
i found the Video on you tube about fault finding RR Parking Sensors.
Post #192677 8th Jun 2013 10:32am
Unlike a D3/4 the FF's PDC does not come on at slow speeds so i would say unlikely... Bow down
Post #192680 8th Jun 2013 10:44am
