![]() | Home > Technical (L322) > Anybody park on a steep slope? |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
I don't park on a steep slope, but I do park on a slightly sloping driveway and a pretty steep driveway when parking at the in-laws.
Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69 ![]() ![]() |
Thanks Bellini - That's how I prefer to operate it. Initial dealer suggestion was to use the transmission brake as the primary, then apply EPB, but I found this made me force it out of park!
Common issue and resolved by adjustment and cleaning. The EPB shoes act on the inside of the hub part of the rear discs and they do need regular adjustment.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
. . . Just spotted, Jim, you have a Galway green car - I bet that's an eyeful - never seen one before ?
Might be a disappointment - only not sure if it is Galway or Tonga!
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
Maybe worth putting the system into 'bedding in' mode and following the procedure to re-set up the dynamic force limit on the actuators. |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
I park on a steep slope and just park up and put the parking brake on while the car's still in D and then move it to P and turn the engine off. As I park I do try and make sure I don't use too much brake pedal pressure, as sometimes it can "jolt" a little when you come off the pedal after turning the car off. Not really had any issues, although occasionally I do get a bong, I just re-apply the parking brake it and goes away. |
Just to say that it's with a dealer under warrenty - they've done adjustments, replaced the main actuator, they have looked at it 6 times without fixing it. Now it's being described as normal!
Don't know about normal but it is very common these days with cars manufactured with the handbrake operating on the rear disks and not on seperate drums or drums incorporated into the rear discs.
Usually it happens when I get back to the car. Looking at ndfi's explanation that does correlate with when I've been driving the car a bit friskily before parking up. When you apply the park brake hold it for 2 seconds and you'll hear it put extra effort into locking properly. |
