![]() | Home > Technical (L322) > Parking sensors inop! |
Check the looms while the bumpers are off for £18 each they are worth replacing as fail more often than the sensors. Two minute job each end with the bumpers off. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35735 ![]() ![]() |
try moving a good sensor to a suspected faulty one to see if its the sensor or the wiring..
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3232 ![]() ![]() ![]() |
Hi Winslow, I have a spare brand new, still in packet, sensor (black) which u can have for £20. Gaz's advice ref new loom is good but check you haven't got a tear or kink in the outer sensor wires as this is where they normally tear due to their thing core. Bit of leccy tape did the trick for mine (hence the unused sensor)
winslo Member Since: 12 Sep 2011 Location: Morpeth, Northumberland Posts: 135 ![]() ![]() |
It is in the garage later today for a thermostat so will be chekcing tyhe other things too
thread detailing the stripdown to clean it all out or replace the non return valve, which tends to get blocked.........
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1230 ![]() ![]() ![]() |
Anyone know the part numbers for the rear and front PDC looms? Tom
give Ducky Dan a shout re loom prices.. ... - .- -.
As above the rear is £18 from Dan and £20 at most other LR Parts (local)
Nice one Gaz! Tom
