Home > In Car Electronics (L322) > 2006 RR HSE Camera Upgrade with a 2010 Camera
kadas
United States 2006 Range Rover HSE 4.4 V8 Chawton White
Hello All.
As many of you know the 2006 Camera is horrible and at night mine was not visable. I swapped it out with a 2010 Camera I got from ebay that was $215 #LR023364 and it required a wire from land rover LR016142 which was around $140.
with some cutting and modifying of the 206 case the radio shop made it work. see below for pics.
Just wanted to help anyone else out who has struggled with a solution. I can not figure out how to upload pictures..
Post #198075 8th Jul 2013 9:17pm
Follow these instructions …. Thumbs Up Thumbs Up
http://www.fullfatrr.com/forum/topic1022.html
http://www.fullfatrr.com/forum/topic1023.html
Post #198081 8th Jul 2013 9:30pm
kadas
This where he modified the stock camera housing to make it fit
this is the old picture from the camera
New 2010 camera image at night and in the day
[/img]
Post #198096 8th Jul 2013 9:56pm
ebajema
Good job mate, picture looks quite good. MY 2010 5.0 SC Galway green and sand interior!!
Post #198141 9th Jul 2013 8:21am
muddycharles
United States 2008 Range Rover HSE 4.4 V8 Bonatti Grey
Question on housing modification
Dear Kadas,
I am interested in this too and was told the new camera has a different offset than the old one and that this requires moving the location of the camera on the rear wing.
Are you saying that the modification you did to the housing (Im assuming the left one is the one you modified in the picture) - will allow the camera to be placed in the same location as the original?
please let me know
Alex 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #199414 18th Jul 2013 3:11pm
kadas
No the camera housing stays in the same place.
You only have to modify the sides of the 2010 camera as shown in the picture above so that it slides into the 2006 housing that is fixed on the rear of the vehicle.
Also the 2010 wire has a hard plastic end that needs to be taken off in order to fit in the 2006 inner housing of the upper tailgate. The 2006 wire that connect to your camera is shorter then the 2010 wire.
Post #199428 18th Jul 2013 6:06pm
kadas
You have a 2008 I just noticed so I am not sure if it is like my 2006. Any decent radio installer will be able to handle the job if you give them the 2 parts.
Post #199429 18th Jul 2013 6:07pm
duckworthparts
Site Sponsor
worth just getting the 2010> camera housing for £6.00 You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #199520 19th Jul 2013 8:41am
kadas
if I knew that I would have totally went that route. That would have saved so much time. Good call!!
Post #199636 19th Jul 2013 7:42pm
muddycharles
2010 Part for Camera Housing
Hi Dan,
You have my atention - what housing? I thought the 2010 Housing is tilted at a different angle or has a different mount point no?
Let me know also a part# - how expensive is it to ship that to the US?
Overfinched
NavTV retrofit
Post #199670 20th Jul 2013 1:56am
Alex, if you want to but a 2010 mount from dan then you ideally would need to drill a new hole approx 80mm further along to mount the later camera in the same spot it is mounted on the late model cars...
That way it clears all of the internal parts and is on the correct plain too Thumbs Up
Post #199684 20th Jul 2013 10:50am
kadas
that probably is not a good idea (drilling a new hole) that is why the installer had to break apart the plastic sleeve that plugs from the new wire into the 2010 camera so that it would clear the internals. I will post pics of the stock end of the 2006 camera and wire that is one piece (camera and wire together) and the conversion I did is 2 parts put together and shaved down to make it fit.
Stock 2006 Harness and Camera is one piece:
New wiring harness: the white plastic part that goes into the the 2010 camera needs to be “broken down” so it clears inside the upper part of the vehicle.
Post #199758 20th Jul 2013 7:50pm
muddycharles
You dont perchance have a picture of the broken down connect
Im wondering how much shaving needs to happen to the connector.
You are 100% sure that putting the camera in the old location will keep the angle on the camera (its the new housing that needs to be moved, not the camera in the housing right?) 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #200153 22nd Jul 2013 11:22pm
kadas
The entire white housing needs to be removed. The pictures you see are with the stock 2006 housing in the factory location, nothing was moved. the housing of the 2010 camera needed to be shaved down to fit in the stock 2006 camera mount on the rear of the vehicle.
hope I answered your questions, let me know if you have any more.
Post #200165 23rd Jul 2013 2:29am
muddycharles
All Set - thank you Kadas!
Much appreciated on my side. 2008 HSE B. Grey
Overfinched
NavTV retrofit
Post #200248 23rd Jul 2013 2:09pm
