![]() | Home > Maintenance & Mods (L322) > Discs Drilled / slotted ? |
Gollycrush Member Since: 05 Jul 2012 Location: Birmingham Posts: 152 ![]() ![]() ![]() |
Anyone fitted Drilled and Slotted Front Discs 360mm dia as these listed? ( To Brembo Calipers )
hoppy Member Since: 11 Mar 2012 Location: birmingham Posts: 165 ![]() ![]() ![]() |
ive got drilled/slotted vented...but not brembo calipers free use of "RSW" all comms to anyone nearby |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Those are not Brembo branded discs though, they are aftermarket ones that happen to be the same size as Brembo ones. I'd be worried they might crack or shatter. They will definitely squeal like pigs and probably wobble quite a bit under decent braking. |
^ Many thanks |
No worries. Unless you go for high quality aftermarket stuff like AP, Brembo or Alcon I'd steer clear of anything else brake wise. EBC pads and rotors can be good, but I'd probably doubt they've tested them on FFRR's anywhere near as much as their core "tuner" market. |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Don't think the drilled / slotted discs would handle high mileage........best sticking with OEM |
Never ever ever ever do drilled!
