![]() | Home > Maintenance & Mods (L322) > Rattles and knocks |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Replaced both front struts due to rh bursting. First drive the car was quiet.
You need to move to a country with decent weather.... |
Last friday I replaced the front upper arm bushes and ball joint on both sides. Pressing those bushes out and in is fun, thankfully I had access to a 15 ton press as my 12 ton one wasn't upto it.
Hi Adrian, glad to hear that the car is back up and running again.
Thanks for you concern re the quake.
After wading in sea water and getting sprayed with in the only way to really wash it off is wading through a clear river and spraying the upper parts of the car quite well to rinse it off but agree with the above that your sterring knuckles need cleaning up and regreasing a lot, use Hight Temp grease so it sticks longer |
I lived in New Plymouth for over a year and we got the occasional tremor there in that time, nothing major.
For grease on cars, I suggest to use Shell Rhodina II. It is designed for open moving parts in the offshore industry so a very corrosive environment. We (my dad and myself) have been using it for decades on the cars and bikes and it is brilliant. Wheel nuts/bolts, no problems after you have used it on the threads or mating surfaces. MY 2010 5.0 SC Galway green and sand interior!!
