Home > Maintenance & Mods (L322) > TDV8 Fuel Filter Change - How to Change - Anyone?.
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
Does anyone have instructions, with pictures (either DIY or LR publication) for changing the fuel filter on a 3.6 TDV8 FFRR ?.
Thanks
Carl
Post #94237 24th Nov 2011 9:02pm
carlos50
Bump
Post #95781 2nd Dec 2011 6:20pm
I would think it was a straight forward job, but best fill the new filter with diesel before fitting
Post #95786 2nd Dec 2011 6:44pm
carlos50
Have read that turning the key to P2 a few times will prime the filter, not sure if that's true or not though?
Post #95788 2nd Dec 2011 6:56pm
wealy
Is this a simple enough job?
Post #201469 30th Jul 2013 10:00am
Brewster
England 2006 Range Rover Vogue SE TDV8 Buckingham Blue
Did mine last year and it was a very simple job made complex !!
In theory should take no more than 5 minutes if working on a brand new car took me about an hour.
Problem for me was the castellated locking ring which holds the filter in place was stuck and having read all the stuff in the manuals about the correct way to turn it I wasn't confident I wouldn't break it it. So in the end took the full filter assy off the car and did it on the bench. Turned out the ring was well crudded up with road grime mud, dead beetles and the like etc. etc. !
I cleaned the housing and filter assembly and lubricated the ring with silicone grease after which it was possible to simply turn the ring by light hand force and remove and reinstall the filter quite easily.
From memeory the filter cartridge has an arrow which is aligned to one on the housing
I would suggest getting a genuine part as opposed to a pattern one and if you do remove the filter housing blank off all the hoses and fittings as you MUST keep everything scrupulously clean.
Hope this helps Sir ...Always time for a brew !!
2006 TDV8 Vogue SE
Post #201541 30th Jul 2013 3:35pm
wealy
Thanks - tip top description!
Post #201716 31st Jul 2013 1:59pm
wealy
Did mine yesterday and followed your brilliant instructions - simple as pie!
I didn't fill mine with diesel as I didn't want to risk spilling any. Just switch the ignition on and off a few times and then start it - it self bleeds.
A must is to line the arrow up on re-assembly.
Simple.
Post #202819 7th Aug 2013 2:59pm
joffa42
United Kingdom 2006 Range Rover Vogue TDV8 Bonatti Grey
Where is this description/instructions
I can't see any instructions in this thread...
Post #495723 16th Nov 2018 2:40pm
pretty sure its the same as the tdv8 4.4 so have a read of that thread in the wiki or download the workshop manual [link in the wiki]
Post #495725 16th Nov 2018 2:50pm
l322novice
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
I changed mine today. If you look at the top bit of the filter, there is a collar which needs to be undone. It's undone clockwise looking from the top. It's usually quite tight, so I used a strap wrench to undo it. The major issue is a lack of space so it also helps to undo some of the fuel pipes around the housing too, maybe take a picture before you start so you know where everything goes.
It's not too hard. As the vehicle was designed under BMW where everything fitted, while under Ford I suppose it was a different story!
Post #502964 27th Jan 2019 4:40pm
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I find removing it in its entirety is easier in the long run.
It’s quite and messy and the stupid lock ring is a pain.
Easier to remove it and change the filter 2007 3.6 TDV8
Post #503007 28th Jan 2019 7:07am
