![]() | Home > Maintenance & Mods (L322) > TDV8 Fuel Filter Change - How to Change - Anyone?. |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
Bump |
I would think it was a straight forward job, but best fill the new filter with diesel before fitting |
Have read that turning the key to P2 a few times will prime the filter, not sure if that's true or not though? |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Is this a simple enough job? |
Brewster Member Since: 11 Sep 2012 Location: East Yorkshire Posts: 26 ![]() ![]() ![]() |
Did mine last year and it was a very simple job made complex !!
Thanks - tip top description! |
Did mine yesterday and followed your brilliant instructions - simple as pie!
joffa42 Member Since: 16 Nov 2018 Location: Exeter Posts: 2 ![]() ![]() ![]() |
I can't see any instructions in this thread... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35673 ![]() ![]() |
pretty sure its the same as the tdv8 4.4 so have a read of that thread in the wiki or download the workshop manual [link in the wiki] |
l322novice Member Since: 15 Jan 2016 Location: South Posts: 32 ![]() ![]() ![]() |
I changed mine today. If you look at the top bit of the filter, there is a collar which needs to be undone. It's undone clockwise looking from the top. It's usually quite tight, so I used a strap wrench to undo it. The major issue is a lack of space so it also helps to undo some of the fuel pipes around the housing too, maybe take a picture before you start so you know where everything goes.
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
I find removing it in its entirety is easier in the long run.
