Home > Maintenance & Mods (L322) > Help please - yellow engine light
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Dear Forumees
Is car safe to drive with yellow engine light ?
Car has oil (looks clean) & water, no funny smells or noises. Bought in Jan, and was serviced (allegedly)
Behaved very well during 3 hour motorway drive yesterday....
I appreciate I need to get codes read etc , but won't get to a garage before weekend..
Mrs is going potty, as needs car , 3 kids at home for school holidays!
Stuck the battery on the CTEK overnight ...
Anything I can check ? Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #201604 30th Jul 2013 8:45pm
a yellow engine light suggests a possible problem with your engine management system ,i'd get it to a garage asap.. ... - .- -.
Post #201606 30th Jul 2013 8:49pm
RR2008HSE
Solid yellow engine light, or flashing light? It's important. Flashing light means pull over as quickly as possible and get the car towed away for repairs.
Solid yellow means an engine fault has been detected and logged. Ideally, the car should see a mechanic as soon as is convenient. I got the yellow engine light a while back. Puzzled as the car ran beautifully. The light went out about two weeks later. Mechanic later read the logged fault - misfire on ignition in two cylinders. It was just an instantaneous fault. The car extinguished the yellow warning light on its own after x # proper starts and x # hours operating normally. He put it down to a random bit of bad gas. We fixed nothing and it never came back. Car recently passed a thorough inspection without problems.
You checked for visible problems - so far, so good. Fuel economy will also give a clue if something's wrong. If I was crossing the Sahara, I'd get it sorted immediately. A few around town jaunts are probably fine until the weekend. (IM NOT A MECHANIC AND I ONLY SAID PROBABLY.). My cars the Jag 4.4 NA petrol. It may be different on other engines. Don't sweat it and check it on the weekend. Good luck!
Post #201611 30th Jul 2013 9:01pm
Martin
Site Admin
Yellow engine light normally denotes an issue relating to engine emissions - could be EGR fault or similar.
Post #201614 30th Jul 2013 9:06pm
E4 GUY
Cheers , hopefully she isn't going too far/fast.
Light is solid yellow.
I ran it very low on petrol yesterday, as it was guzzling it on a 3 hour , very wet, high speed (70mph officer) motorway run.
Filled it with 98 octane. Maybe rubbish sainsburys stuff Whistle
Fuel economy ! ? What fuel economy.. It's an SC Rolling with laughter
Will get to a garage ASAP, and report back Alcohol and eBay is never a good mix
Post #201616 30th Jul 2013 9:09pm
Martin
Site Admin
OK - probably not EGR then Thud Embarassed
Post #201617 30th Jul 2013 9:10pm
RR2008HSE
Fuel economy? I hear you. At least you're not a diesel guy who thinks there's something wrong because the fuel economy has PLUNGED to ONLY 40 mpg. Mr. Green
Seriously, I'm betting it was a bit of grit or momentary lack of fuel from running low.
Post #201625 30th Jul 2013 9:26pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
It's one of many things which could include: misfire, coil packs, lean / rich mixture, emissions etc. unless you've noticed the car running lumpy I'd say it's likely to be emissions related. Mine sometimes throws a lean code if I "make too much progress".
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #201683 31st Jul 2013 9:09am
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I have been running with a yellow light for 5 years on my 4.2sc.
Initially every gadget and sensor was replaced with no success. It gets reset from time to time but comes on again eventually.
I just gave up as it runs perfectly well.
One day, I will stumble across the reason, so keep us up to date on progress as it at help me. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 L322 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #201707 31st Jul 2013 11:19am
