![]() | Home > Maintenance & Mods (L322) > How to change those pesky $%^& rear calipers on a TDV8. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
great how to.. |
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
| GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61
Why didn't you change the carrier as well? |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Because it doesnt come as part of the caliper kit, and there are pretty much no moving parts bar the sliding pins. Dead easy to swap over just two more bolts, but didnt see the point, when the dealer swapped my caliper the other side they just changed the body.
| TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848
Remember to road test slowly at first and try a few stops within 100m of your house. If you've cocked up the bleeding you won't want to discover it at the first junction you come to |
Think my rears need doing, squeeling and a lot of heat on the rears after a journey.
You can paint them in a zinc paint before you do the job... Lasts for ages |
Use ukpas25 for 25% off on ecp.
Would have done both mine Craig, but the MD did the other one only 6 months ago, i could have had this one done as well but was going away in the car and needed it asap. Next time it will be both and the discs. There is nothing that can't be fixed with a hammer😜😜
| taskam Member Since: 01 Apr 2011 Location: Shandon Posts: 121
I had the same on one of my rear pads when I replaced it. It was tight in the carrier and squealed badly when it warmed up.....seemed to jam. I eased the lugs just a tad on the top and bottom of the pad with a file which allowed it to slide more freely.... heating and squealing fixed. 2007 TDV8 Vogue SE Java Black |
Did that on mine when i swapped them for the mot last year.
Changed them over the weekend, easy job really.
| goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196
can i confirm that no 'computer' reset has to be done because of the electric hand brake? 2011 4.4 TdV8 Nara Bronze |
You don't touch the handbrake when changing the callipers.
| All times are GMT |
