Home > Maintenance & Mods (L322) > Trans failsafe prog - Help |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
If it happens again, stop, turn the ignition off and pull the key out. Then restart the engine and the error should have gone and it will drive fine.
3rd Aug 2013 11:38pm |
doodoo Member Since: 08 Apr 2013 Location: Buckinghamshire Posts: 22 |
Thanks. It was a bit of a panic on a hill at a busy junction when it wouldn't move apart from backwards! |
4th Aug 2013 8:36am |
TtheArab Member Since: 26 Apr 2013 Location: Dunblane, Scotland Posts: 89 |
TFSP error on mine was cleared by cycling the ignition 10-12 times. Only moving backwards though actually sounds like front diff problem where the shaft strips the spline. Did you check the car had the factory recall to fit re-engineered part for front diff ?
4th Aug 2013 9:38am |
Yes the paperwork is there for the recall in November 2010. It appears fine once again this morning but don't want to venture too far from home as presumably it will go again. But I will get the battery tested first. Thanks |
4th Aug 2013 9:52am |
adigorn Member Since: 18 Mar 2010 Location: West Midlands/Birmingham Posts: 204 |
I am afraid we are looking at faulty box here (i know it had been reconditioned but...)
4th Aug 2013 10:02am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
4th Aug 2013 10:37am |
Guys not to say your opinion is any less valid but from what OP has shared your assumption that the box has gone is a tad OTT. We all know the FF is a pain in the ass with error messages calculated to send you into meltdown which can be from something as simple as a bad connector or low battery.
4th Aug 2013 5:59pm |
Thanks chaps for all your comments and ideas. I do still have the paperwork. Invoice dated March 2011. Technician comments at the time were (and does sound a little similar now)
4th Aug 2013 6:49pm |
Before you commit to another gearbox get in touch with RRPhil. It sounds more than a bit "unlucky" for another gearbox to go after only 35k. |
5th Aug 2013 4:56pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3078 |
Not certain but i think RRphil is more a ZF/Petrol Gearbox man, not a GM box expert. Try him anyway as he knows Sh@tloads more than most! |
6th Aug 2013 12:09am |
Update:
8th Aug 2013 12:11pm |
Oh dear..... I would be all over the guys that did the replacement despite the 12 mths thing. I suspect if they are a reputable crew they would be pretty mortified that this has happened.
8th Aug 2013 12:45pm |
Thanks. I have approached them. The response was at best, very disappointing. Last edited by doodoo on 8th Aug 2013 4:30pm. Edited 1 time in total |
8th Aug 2013 3:14pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
It seems there's huge variability in the quality of gearbox rebuilds. |
8th Aug 2013 3:29pm |
