Home > Maintenance & Mods (L322) > Trans failsafe prog - Help
doodoo
England 2012 Range Rover Westminster TDV8 Zermatt Silver
I had the Trans Failsafe prog message first come up a couple of weeks ago but it still drove fine and has until today. Then on a hill it wouldn't pull away and then this message came up. It eventually moved and I limped home.
I live Near Berkhamsted, on the Beds Bucks and Herts borders. Does anyone know anyone in one of these counties who would give a diagnosis and and then be able to repair at an affordable price.
This is my first RR. Had it about 4 months. 54 plate 2.9 Diesel. It has been regularly serviced and had new gear box and torque converter in 2011
Thanks in advance for any help and advice from anyone.
DD Sad
Post #202206 3rd Aug 2013 9:25pm
Budgie
If it happens again, stop, turn the ignition off and pull the key out. Then restart the engine and the error should have gone and it will drive fine.
That'll keep you moving until you can get it seen too. Wink
Post #202218 3rd Aug 2013 11:38pm
doodoo
Thanks. It was a bit of a panic on a hill at a busy junction when it wouldn't move apart from backwards!
Post #202232 4th Aug 2013 8:36am
TtheArab
2003 Range Rover HSE 4.4 V8 Giverny Green
TFSP error on mine was cleared by cycling the ignition 10-12 times. Only moving backwards though actually sounds like front diff problem where the shaft strips the spline. Did you check the car had the factory recall to fit re-engineered part for front diff ?
If it is this don't worry as it is a well understood job by most LR specialists.
If it isn't the diff then I would test the battery. Getting a new one certainly helped my FF stop producing so many errors.
Post #202243 4th Aug 2013 9:38am
doodoo
Yes the paperwork is there for the recall in November 2010. It appears fine once again this morning but don't want to venture too far from home as presumably it will go again. But I will get the battery tested first. Thanks
Post #202246 4th Aug 2013 9:52am
adigorn
I am afraid we are looking at faulty box here (i know it had been reconditioned but...)
description fits:
when there is a lot metal filings inside the box, the oil pump pick the m up and block filter
(lost of drive) when car cool down and metal filings fall down you can drive (short while)
Changing oil and filter will help (short term, but its not a fix !!!!!!!!!!!!!!!!!)
Other possibilities T/Box lost calibration, or one of front half shafts pops out from diff
very unlikely in your case
Thumbs Up ,
Post #202249 4th Aug 2013 10:02am
I didn't want to be the one to say that but it sure sounds like it.
Might also be blocked cooler? (see SaintV8's replacement on wiki)
(You were on a hill so is fluid level an issue?)
Unless you can DIY, off to dealers/indie for fluid check and fluid/filter exchange as a first effort to resolve and some diagnosis on Testbook. .
Post #202261 4th Aug 2013 10:37am
TtheArab
Guys not to say your opinion is any less valid but from what OP has shared your assumption that the box has gone is a tad OTT. We all know the FF is a pain in the ass with error messages calculated to send you into meltdown which can be from something as simple as a bad connector or low battery.
Let's not scare the poor lad to death here. I would say go at this systematically and test :-
1. Battery - thread is on here how to do that
2. Transfer Box Motor - RRPhil has a thread on here and whilst its a bit more involved even I managed it
After that if its still not sorted go to an indie and ask them to put diags on it using genuine LR tester v's cheaper one (cheaper one cant diag Transfer Motor etc).
Fingers crossed it isn't the box.
Final thought : do you have the papers from the box replacement ? Might be worth chasing them up ?
Post #202318 4th Aug 2013 5:59pm
doodoo
Thanks chaps for all your comments and ideas. I do still have the paperwork. Invoice dated March 2011. Technician comments at the time were (and does sound a little similar now)
Investigate for no drive - Suspect gearbox failure carried out diagnostic checks found engine output speed greater than gearbox output shaft speed, confirmed gearbox clutch slipping due to torque converter failure, requires new gearbox and torque converter.
Removed gearbox and reconditioned fitted new torque converter, oil cooler and cooler pipes due to contamination.
Its done 35K miles since then. They gave a warranty for 12 moths/12000 miles. If they were a little nearer I would have approached them.
Shame has had been enjoying driving it very much last few months and is in great condition both inside and out. Fingers crossed it isn't the worse case scenario.
DD
Post #202326 4th Aug 2013 6:49pm
TtheArab
Before you commit to another gearbox get in touch with RRPhil. It sounds more than a bit "unlucky" for another gearbox to go after only 35k.
Post #202483 5th Aug 2013 4:56pm
Dolphinboy
Not certain but i think RRphil is more a ZF/Petrol Gearbox man, not a GM box expert. Try him anyway as he knows Sh@tloads more than most! Bow down
Post #202569 6th Aug 2013 12:09am
doodoo
Update:
Diagnotic test says 3rd gear is slipping.
Car being transferred to specilist gearbox hospital later
Not feeling hopeful.
Crying or Very sad
Post #202943 8th Aug 2013 12:11pm
TtheArab
Oh dear..... I would be all over the guys that did the replacement despite the 12 mths thing. I suspect if they are a reputable crew they would be pretty mortified that this has happened.
Good luck.
Post #202947 8th Aug 2013 12:45pm
doodoo
Good luck.
Thanks.
I have approached them. The response was at best, very disappointing.
Post #202956 8th Aug 2013 3:14pm
It seems there's huge variability in the quality of gearbox rebuilds.
Post #202959 8th Aug 2013 3:29pm
