Home > Maintenance & Mods (L322) > Replacing belts on supercharged
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I read the 'how to' in the wiki on radiator removal with interest as I was planning to replace the primary and secondary belts which requires uncoupling the viscous fan.
I had an exploratory root around yesterday to see if the task would be much different on the SC. I removed the engine cover and the air intake ducting only to find a maze of pipes and a manifold casting level with the top of the rad obscuring any realistic access to the fan coupling, tensioners and belts.
Has anyone had any success with this task on the SC who could share a few tips or is it just a major pain in the ****. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2011 Discovery 4 3.0 HSE
2015 Discovery 4 HSE Lux
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #202288 4th Aug 2013 2:20pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Is it the plastic intake tube you're seeing near the rad? It's two jubilee clips and a tight fit pcv return hose. Easily removed, bit of a Censored to get back on. You can do the belts with this removed and it's not torque sensitive when you put it back on. You can remove the intake plenum but that's a bit of a sod and not necessary. Be prepared to skin knuckles doing it though ...
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #202296 4th Aug 2013 3:39pm
RRBlue
Thank you for your reply.
I removed the black plastic intake tube. As you sau, very simple. Undetneath are the web of cooling pipes that obscure the access. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #202311 4th Aug 2013 5:13pm
TheAllSeeingPie
You have to unbolt the radiator and remove the viscous fan to do the belts. It's an arse but once done the belts are quite easy.
Post #202316 4th Aug 2013 5:40pm
RRBlue
Agree. That presumably means draining the aircon as there is pipe across the top of the rad. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
1992 Mercedes 300D
Post #202320 4th Aug 2013 6:02pm
