![]() | Home > Technical (L322) > Suspension levelling |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i'd try going to the off-road setting and back down to access afew times to see if it settles, other than that get a IIDTool and manually adjust the height.. ... - .- -.
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Replacing bags shouldnt affect hieght in normal running unless your disturbed the height level sensors.
| Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537
Stan, I change the height regularly (Offroad hieight when I park in the supermarket, saves door dings, and access height for when the old man is in the car or for the dog, she's getting on a bit and doesn't like the jump!) - anyway,so the car has been raised and lowered plenty of times.
Should look like little black or white boxes IIRC about 1*1*1" and have a small rod on them connecting to each suspension arm. Would look strange to anyone who hasn't dealt with a non-normally sprung car, like a small sensor pack and push rod attached |
OK, I'll check, I can't remember seeing/noticing/knocking those!
