![]() | Home > Maintenance & Mods (L322) > Passenger Door Locked shut |
mackempete Member Since: 17 Mar 2013 Location: Durham Posts: 60 ![]() ![]() ![]() |
Quite annoyed at myself for letting it get this far. I came to fix this problem yesterday and now its even worse |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35779 ![]() ![]() |
you could try a battery disconnect or change the key fob just in case its an electrical problem.. ... - .- -.
wats39 Member Since: 08 Jul 2012 Location: fife Posts: 77 ![]() ![]() ![]() |
Had the same happen to mine. Got it open by banging the outside of the door with my hand around the handle while locking and unlocking it with the key fob. '04 td6 se
WD40 has done nothing yet. I'll try the banging approach later on. I'm wondering if i can remove the screws and partially prise off the door car to get some access to the lock, even if its only to get a WD40 straw closer to where it needs to be. Looking at the drivers door i'm thinking this is a complete no go with the door locked.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
make sure your battery is good and fully charged, this made a big difference on one of mine - insufficient kick in the actuator to force the button up.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
Around the pop up button on the door is a black circular plastic trim.
Tried it with the engine running. Revved the car quite high so alternator would be putting out good voltage and operated the dash button repeatedly. No luck ![]() |
I'll try this one tonight, good thinking ![]() |
nicedayforit, your idea worked a treat thanks very much mate.
Glad it worked |
Definitely seems to be a common problem. Admittedly those smarter than me rectify it before it gets this bad :]
