Home > Maintenance & Mods (L322) > Passenger Door Locked shut
mackempete
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
Quite annoyed at myself for letting it get this far. I came to fix this problem yesterday and now its even worse Mad
For a week or so the passenger front door WOULD intermittently open with the central locking, a couple of locks and unlocks generally sorted it. Then For a couple of weeks the passenger door hasn't opened at all when you press the key fob, but has opened when you pulled the interior handle. Figured it would just be a linkage issue, electrical connection or something that would be immediately obvious with the door card off.
Unfortunately when i came to do this yesterday the situation has worsened. I now cant open the door at all using the interior handle. Obviously this means I cant get the door card off to see whats going on. Anyone got any suggestions?
I've read a few posts and there is talk of butchering door cards, cutting holes in doors etc. I saw one post about squirting WD40 down the door nipple to reduce the friction on the mechanism. This is going to be my first port of call over the weekend.
Post #203128 9th Aug 2013 4:13pm
you could try a battery disconnect or change the key fob just in case its an electrical problem.. ... - .- -.
Post #203129 9th Aug 2013 4:20pm
mackempete
I don't think the key fob is at fault. It unlocks all the other doors upon the second press of the unlock button. I think if there is an electrical issue its liable to be inside the passenger door, or isolated to the wiring pertaining to that doors central locking.
Post #203130 9th Aug 2013 4:24pm
I would certainly try the WD 40 first and just be patient, it can take a while to work itself in.
You need a good battery, fully charged. Thumbs Up
Post #203131 9th Aug 2013 4:28pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Had the same happen to mine. Got it open by banging the outside of the door with my hand around the handle while locking and unlocking it with the key fob. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #203339 10th Aug 2013 11:09pm
mackempete
WD40 has done nothing yet. I'll try the banging approach later on. I'm wondering if i can remove the screws and partially prise off the door car to get some access to the lock, even if its only to get a WD40 straw closer to where it needs to be. Looking at the drivers door i'm thinking this is a complete no go with the door locked.
Other option is to take it to a specialist, however if they have no cunning tricks and are just going to butcher the door card i'll do it myself.
Post #203937 14th Aug 2013 11:40am
Vogue
make sure your battery is good and fully charged, this made a big difference on one of mine - insufficient kick in the actuator to force the button up.
also play with the dash mounted unlock switch - this also worked when the button didn't. Exhaust all options prior to ripping your door card off Thumbs Up
you will be surprised how much difference a crap battery makes to this vehicle Sad 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #203940 14th Aug 2013 11:56am
Around the pop up button on the door is a black circular plastic trim.
If you gently prise this trim off you should be able to get hold of the top of the pop up button with a pair of thin nosed pliers.
If you can, pull the button up and see what happens. Thumbs Up
Don't forget a new door card is about £600+. Shocked
Post #203941 14th Aug 2013 12:04pm
mackempete
Tried it with the engine running. Revved the car quite high so alternator would be putting out good voltage and operated the dash button repeatedly. No luck Sad
Post #203963 14th Aug 2013 3:04pm
mackempete
I'll try this one tonight, good thinking Smile
Post #203964 14th Aug 2013 3:05pm
mackempete
nicedayforit, your idea worked a treat thanks very much mate.
pulled on the door nipple and it came out but went back in again. pulling on it while working the interior door handle and it unlocked the door properly Smile
Post #204322 16th Aug 2013 11:25am
Glad it worked Thumbs Up Saved a door card. Very Happy
Useful to know, seems to be a common problem.
Post #204330 16th Aug 2013 12:48pm
mackempete
Definitely seems to be a common problem. Admittedly those smarter than me rectify it before it gets this bad :]
I'll put some pictures up of the proper fix when I get chance to take the door card off.
Post #204334 16th Aug 2013 12:58pm
