![]() | Home > Technical (L322) > Steering wheel wobble under braking |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 ![]() ![]() ![]() |
Aye, might be the discs. I had similar on my disco4. Only under light braking above 50mph but as you said if you are pressing a bit harder the steering firms up. At slower speed no wobbles at all.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
Allegedly replaced before me 10,000 miles ago, feels that way, will send to my Indy next week, once my TD6 has been let out |
Had the wheels refurbished recently, may be that? 2013 L405 Autobiography Baltic Blue
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Easiest thing to check...... Did you retorque your wheels after a couple of trips out after they were refurbed? Can take a while for the nuts to seat in with the new coating. There is nothing that can't be fixed with a hammer😜😜
Northernmonkey, sorry never hear of that, will take it in for a balance etc. tomorrrow, Cheers guys |
May not be the cause, but easy to check. Mine worked loose in the first week, but were fine after retorqued. There is nothing that can't be fixed with a hammer😜😜
Cheers |
Bushy513 Member Since: 25 Feb 2013 Location: Colchester Posts: 392 ![]() ![]() ![]() |
It could also be a ever so slightly seized calliper on the front. Imagine if one of the pots operated a little bit slower than the other side it would cause slight wobble in the steering as one side is being slowed down more than the other. But once you brake harder pressure is evenly distributed. They could just need a quick clean.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16365 ![]() ![]() ![]() |
1 Tighten wheels, then 2 balance wheels, then 3 check for ball joints/bush wear, then 4 change brake discs |
