Home > Technical (L322) > Steering wheel wobble under braking
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Guys/Gals (are there any on here, gals that is Smile )
Probably a well asked question however I am not technical in any way, when I brake at anything above 50MPH I get a small wobble through the steering wheel. Only happens under normal braking, full on the pedal produces nothing and stops OK. Can anyone give me a hint before I put it in the shop.
I would hazard a guess at discs but only if I wasn't in such esteemed company.
Thanks 2013 L405 Autobiography Baltic Blue
2007 L322 Vogue Buckingham Blue
Post #208742 7th Sep 2013 6:35pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Aye, might be the discs. I had similar on my disco4. Only under light braking above 50mph but as you said if you are pressing a bit harder the steering firms up. At slower speed no wobbles at all.
Replaced the discs and no wobble Thumbs Up
Obviously it could be something in the steering linkage as well (there was a TSB on he disco for it) but how old are the discs?
Might be the best place to start!
G
Post #208747 7th Sep 2013 7:12pm
Rosco
Allegedly replaced before me 10,000 miles ago, feels that way, will send to my Indy next week, once my TD6 has been let out Very Happy 2013 L405 Autobiography Baltic Blue
Post #208748 7th Sep 2013 7:25pm
Rosco
Had the wheels refurbished recently, may be that? 2013 L405 Autobiography Baltic Blue
Post #208750 7th Sep 2013 7:42pm
Easiest thing to check...... Did you retorque your wheels after a couple of trips out after they were refurbed? Can take a while for the nuts to seat in with the new coating. There is nothing that can't be fixed with a hammer😜😜
Post #208770 7th Sep 2013 9:43pm
Rosco
Northernmonkey, sorry never hear of that, will take it in for a balance etc. tomorrrow, Cheers guys Smile 2013 L405 Autobiography Baltic Blue
Post #208773 7th Sep 2013 9:50pm
May not be the cause, but easy to check. Mine worked loose in the first week, but were fine after retorqued. There is nothing that can't be fixed with a hammer😜😜
Post #208775 7th Sep 2013 9:58pm
Rosco
Cheers Thumbs Up will try that 2013 L405 Autobiography Baltic Blue
Post #208789 7th Sep 2013 11:12pm
Bushy513
United Kingdom 2003 Range Rover Vogue Td6 Monte Carlo Blue
It could also be a ever so slightly seized calliper on the front. Imagine if one of the pots operated a little bit slower than the other side it would cause slight wobble in the steering as one side is being slowed down more than the other. But once you brake harder pressure is evenly distributed. They could just need a quick clean.
Just an idea if nothin else works. Bushy
2003 RR Vogue Monté Carlo Blue
Post #208827 8th Sep 2013 10:19am
1 Tighten wheels, then 2 balance wheels, then 3 check for ball joints/bush wear, then 4 change brake discs Thumbs Up
Cheapest line Thumbs Up
Post #208833 8th Sep 2013 10:39am
