![]() | Home > Wheels & Tyres > Need new winters - think it'll be Vreds |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Currently have Dunlop Grandtrek WT M3's - which is an excellent winter tyre - with the exception of poor rolling resistance. They came with the car when I bought it 3+ years ago. This year I've run them all year as the tread was a bit low for another winter so thought I'd get some life out of them in the summer before replacing. I actually have dedicated summer wheels (19's) that I normally use in the summer.
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
I run Nokians on my wifes car. I had them on my Range last winter and they are fine to run all year.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
an indicator of a good tyre would be what other users in your area have on their cars ..if the majority have vredestein [or any other make] then there must be a good reason for that.. ... - .- -.
I'm not having a go at the Nokian's Gaz - they look an excellent tyre, just in the tests the Vreds beats them in snow. In wet weather they're better. Doesn't mean they're bad in snow. They're also not available in 235/65 R18, although that's not a big issue. |
Half of Northern Europe (Snowbound) run on Nokians....
Kurt, why do you want 235/65 R18 - Bit narrow that?
| tboner001 Member Since: 22 Jan 2011 Location: Bucks Posts: 691
i agree seems rather small Far to many gone... |
You're more impressed with girth? |
Why go thinner "Girth" than factory Standard |
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1531
To be honest that's why I discounted the Nokians, I could only see them in 275 width, I know I can get close enough to standard but the insurance is a bit of a worry.
a wide tyre isnt always necessary in snow..
My comment was about getting 235 "Thinnies" instead of Standard 255. |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
thats a whole 80mm of width lost across all the tyres and a few inches of tread when you think about the whole area (cant be bothered to work it out) but with the weight of an FF a narrow tyre will help cut into the snow a lot better and provide more pressure for cutting in as well as pushing the stuff out of the way.
They are factory standard Gaz, I'm not doing anything wierd. Here's the standard factory sizes.
| All times are GMT |
