![]() | Home > Technical (L322) > LED running lights |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
I was thinking of the round DRLs on eBay that will replace the fog light inner unit completely.... |
there isnt a lamp unit that is a direct replacement for the fog unit, i looked and couldnt find anything... ... - .- -.
i'd like to be proved wrong as i'd like to buy them.. ... - .- -.
This is the item I was thinking of....
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
They look nice, but -
kind of defeats the point - you would really need to wire them differently. And -
seems all wrong - I thought DRL's were supposed to be super bright & that's why they need to go off / be dimmed once your side lights are on ? |
Go the whole hog like I did |
I think powerful are making it clear that you won't get the same light thrown out as you would from the range of a normal fog? I think these LEDs work in a different way., ie they could be extremely bright to look at, but without a lens pushing the light forward they won't be as effective at projecting it.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
All three varients of the L322 have different fog lamps... Neither will fit in the other ![]() |
Thanks Craig, saved me looking, powerful ad lists them as fitting 2002 on!! |
http://www.powerfuluk.com/products/pair-of...-l322.html
Sorry, looked at the eBay ad, the blurb says 2010 on, but the application lists show 2002 on. |
the only way i have found to 'get' the fogs as drl's is to replace the halogen bulb with a led/smd ,rig the drl bulb wiring to a drl switch and then either stick resisters in line for the old fog wiring or switch off the hot/cold monitoring with something like the IIDTool..
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
I bet the car wouldn't pass its mot with te powerful lights replacing the fogs... 2009 Vogue TDV8 Nara Bronze
Front fogs aren't mot testable items, they can be broken/faulty and the car will not fail because of them. |
