![]() | Home > Maintenance & Mods (L322) > Tow Bar Armature - Gaskets ? |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Fitting instructions: http://www.fullfatrr.com/forum/post205899.html#205899
Mark.abersoch Member Since: 23 May 2013 Location: Wirral Posts: 148 ![]() ![]() ![]() |
I think you are meant to have some. I fitted a used in on mine the other week and just used some silicone!
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Thank you, gentlemen.
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
You will find a thin foam gasket left stuck to the car after you remove the existing brackets, if it's like mine. I fitted a used bar, like Mark said, use a bead of silicone and all should be well. |
Simple1 Member Since: 01 Jun 2013 Location: Somerset Posts: 112 ![]() ![]() ![]() |
As stated, when I fitted mine, the seals from original bar remained so I have two new ones in a bag if you need them TDV8 Vogue SE 2009.
Thanks for the replies, chaps.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I had a bad water leak that I traced to the armature gaskets - I was going to be fitting a towbar at some point so I bough the Westfalia armature and that came with the gaskets - I did try and search for a LR part number but couldnt get one for the gaskets.
Plant Member Since: 01 Oct 2013 Location: Wirral Posts: 38 ![]() ![]() ![]() |
I don't suppose you still have these do you? I have just bought second hand Armature and need to source the gaskets. |
Yep sat on top of my tool box |
