Home > Maintenance & Mods (L322) > Tow Bar Armature - Gaskets ?
TugRR
To those who have fitted the tow armature themselves . . .
Have I dreamt this up, or is there a gasket of some sort between the (two) vertical plates and the car body which are bolted to the rear of the body underneath ?
I have a used armature to install, but don't have the instructions. I've read other threads ref fitting and I believe I've seen such a gasket on a diagram somewhere - can't remember where Rolling Eyes
So, if anyone can help out what the gasket material is, I'd much appreciate it !
Thumbs Up Where do you go after one of these . . . ?
Post #213194 30th Sep 2013 2:33pm
Martin
Site Admin
Fitting instructions: http://www.fullfatrr.com/forum/post205899.html#205899
They are thin foam AFAICR
Post #213199 30th Sep 2013 2:52pm
Mark.abersoch
United Kingdom 2010 Range Rover Vogue SE TDV8 Bonatti Grey
I think you are meant to have some. I fitted a used in on mine the other week and just used some silicone!
I used quite abit so it should give it the the protection. 2009 TDV8 Vogue SE - Bonatti Grey
Post #213200 30th Sep 2013 3:04pm
TugRR
Thank you, gentlemen.
Martin, that will be the diagram I was thinking of then Rolling Eyes
Cheers
Post #213209 30th Sep 2013 4:03pm
paneldamage
You will find a thin foam gasket left stuck to the car after you remove the existing brackets, if it's like mine. I fitted a used bar, like Mark said, use a bead of silicone and all should be well.
Post #213302 30th Sep 2013 10:54pm
Simple1
United Kingdom 2009 Range Rover Vogue SE TDV8 Santorini Black
As stated, when I fitted mine, the seals from original bar remained so I have two new ones in a bag if you need them TDV8 Vogue SE 2009.
TDV8 Sport. Gone. Loved it but it didn't love me!
Other toys in the cupboard.......
Post #213570 2nd Oct 2013 10:33am
TugRR
Thanks for the replies, chaps.
Simple1 - I'll see how bad mine are when I take the tow brackets off and I'll get back to you - Thanks
Post #213575 2nd Oct 2013 11:09am
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I had a bad water leak that I traced to the armature gaskets - I was going to be fitting a towbar at some point so I bough the Westfalia armature and that came with the gaskets - I did try and search for a LR part number but couldnt get one for the gaskets.
When I fitted the armature, i put some industrial grade gutter sealant around the armature / body joint just be to be sure - it's been fine since Thumbs Up Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #213630 2nd Oct 2013 2:35pm
Plant
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I don't suppose you still have these do you? I have just bought second hand Armature and need to source the gaskets.
Post #215042 7th Oct 2013 9:31pm
Simple1
Yep sat on top of my tool box Thumbs Up TDV8 Vogue SE 2009.
Post #215610 10th Oct 2013 8:35am
