Home > Maintenance & Mods (L322) > play in steering wheel
Vogue wrote:
Cam-Tech-Craig wrote:
Check the coupling on the coloum to the rack... Sounds like it maybe loose...
credit where credit is due, your knowledge on these vehicles keeps impressing Thumbs Up
Bow down Bow down Bow down Thumbs Up
Post #215898 11th Oct 2013 5:26pm
Thumbs Up ok we all hail Craig now - but where are my fu******* Censored wheels !? Twisted Evil Wink Sheep All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #215958 11th Oct 2013 9:30pm
Googsy
Apparently they are coming through Craig's cousin in Bucharest Whistle Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #215960 11th Oct 2013 9:33pm
Laughing Laughing Laughing Thumbs Up
Post #215963 11th Oct 2013 9:42pm
Laughing Laughing Laughing All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #215999 12th Oct 2013 6:41am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Sorry to drag up this old thread.....BUT
I'm suffering play in my wheel also. More noticeable when in a straight line but looking for some more info on how to remedy this. I note you tightened up a "bolt"?? which seemed to fix the issue but how do I identify said bolt..?
Do I need to put the car on a ramp to get under it or can this done from above.? Any clues what to look for as I've never dug deep into the engine bay and am a bit lost.
Thanks in advance all.. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #288791 25th Oct 2014 9:41am
Steering column to steering rack has a universal joint (like a CV joint in a drive shaft) It slides over one another then there is a securing bolt that clamps the two together tight. You can definitely see said item by removing the OSF wheel arch liner (quite a simple job whilst car is in off road height on the floor Thumbs Up )
Post #288793 25th Oct 2014 9:52am
comports
Many Thanks Craig.
I'll give it a look today if I can. It's not a big problem but a little annoying having to correct said steering on a long journey.!
Cheers Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #288794 25th Oct 2014 9:55am
Probably easier if you know someone with a ramp... But if not, above is the easy DIY way sir Thumbs Up
Post #288796 25th Oct 2014 9:57am
