![]() | Home > Maintenance & Mods (L322) > play in steering wheel |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
Apparently they are coming through Craig's cousin in Bucharest |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1763 ![]() ![]() ![]() |
Sorry to drag up this old thread.....BUT
Steering column to steering rack has a universal joint (like a CV joint in a drive shaft) It slides over one another then there is a securing bolt that clamps the two together tight. You can definitely see said item by removing the OSF wheel arch liner (quite a simple job whilst car is in off road height on the floor |
Many Thanks Craig.
Probably easier if you know someone with a ramp... But if not, above is the easy DIY way sir |
