![]() | Home > Technical (L322) > Can't open the car |
Fr_Raf Member Since: 20 Nov 2010 Location: Lyon - Paris Posts: 147 ![]() ![]() ![]() |
You maybe right, but I guess that if i turn on the ignition it would start ?
You're right.
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
having re-read all you have said the drivers door may not be super locked. Try hooking some thing over the drivers door handle & see if it unlocks Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
avoir relu tout ce que vous avez dit la porte du conducteur peut ne pas être super verrouillé. Essayez de brancher quelque chose sur la poignée de la porte du conducteur et voir si elle déverrouille Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
I don't agree, because even if i locked the driver's door with the door's button, immediately after, I turned the key on right to lock the 3 other doors, and close the windows, I think then, that i had a super-lock effect on the car, and if super-locking the car, it certainly disabled the interior handles, and then, the driver's one too, don't you think ?
Thank you to translate what you wrote, it is quite easier to me to understand some messages as english is not my first laguage. I hope my English is not so poor as you have problem to understand what I want to tell you all. My appologies if I killing your language ![]() ![]() |
I dont envy you at all & I hope someone can come up with a solution that helps you. Apart from asking a 17 year old in a hoody that could probably drive it away in 30 seconds |
does one of you went light a candle in a church ?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16379 ![]() ![]() ![]() |
Now go and celebrate in the Pigalle ![]() ![]() ![]() ![]() |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35779 ![]() ![]() |
i was going to suggest the emergency tailgate release but i'm a bit to late..
Hooray |
unfortunately, I'm just a man and not a woman, then I can't to many think at the same time, and driving in Pigalle and seeing girls at the same time is quite dangerous as there is a big concentration of sexy girls in a square meter. |
Indeed |
