Home > Technical (L322) > First post!!
Page 1 of 3 123>
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
First post!!
Good evening guys & gals. I'm about to commit one of the deadly sins as far as car forums go by asking a technical question in my first post so please forgive me!!!
My names Paul and I'm from not so sunny Aberdeen! I own an Epsom Green 02, TD6 Vogue and I absolutely love it even though I sometimes think it hates me!!!
So here I am seeking knowledge and enlightenment! A few weeks back I changed the main rad, thermostat, water pump and belts on my Td6 vogue as the rad had a hole in it. The operation was successful and the cooling system was struck off of my lengthy Rangie to do list! That was until last night when I went to jump in and go to work only to find a wee puddle underneath! After I'd stopped crying and self harming I had quick once over under the bonnet but it was dark and I was sucicidal!!!
So this morning I dropped the splash pan and got the inspection light out. Everything was caked so I spent a while degreasing and drying everything. Gave it ten minutes and got back underneath. To my amazement it was nothing to do with my handy work! No loose clips or nipped pipes But I could see coolant dripping off the rear of the air con compressor. (My compressor is knackered and had no belt on it)
Now this may be a daft question but does the coolant run through the compressor? Or can anyone think of what would be behind there that could leak?
Granted I need to jack it up to get directly underneath as it was only up on the airbags.
Any winning suggestions paid in beer tokens!!
Paul.
Post #217619 19th Oct 2013 9:56pm
Googsy
Welcome Thumbs Up I think you will find its normal . It's to do with the air con but they all do that Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #217620 19th Oct 2013 9:59pm
paul271
Yeah I thought that initially too mate. But my air con compressor is knackered and doesn't have a belt on it and it's coolant that's dripping down from somewhere behind or above the compressor.
Post #217622 19th Oct 2013 10:03pm
Googsy
What colour is the fluid? The cavalry will be along shortly to dig a bit deeper so we can identify where it's coming from Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #217624 19th Oct 2013 10:12pm
If it's coolant it's certainly not normal and as you've guessed, you have a problem. Sorry to say that. Sad
Welcome by the way.
Strange question I know, but you don't sometimes go under the name of Pauline do you? Just we have to check all new members these days. If I don't RRUK will come along and ask. Nothering against transvestites, just one particular transvestite.
Post #217625 19th Oct 2013 10:14pm
paul271
It's blue mate. It's the definitely the coolant I pumped in a few weeks back! Antifreeze with buttering agents, it's just not as nice when you taste it!!!
Post #217626 19th Oct 2013 10:16pm
paul271
Haha!! No Pauline's here mate, but never say never!!
Post #217627 19th Oct 2013 10:18pm
Paul, welcome... The coolant should be pink for a starter... If you have put blue in (by accident) then unfortunately you will need to get it out and replace it with the correct pink antifreeze... Blue is Non organic and will adversly eat your head gasket where as Pink is Organic and will lubricate your gaskets and other parts hence "never the twain shall meet" approach Thumbs Up
Post #217628 19th Oct 2013 11:46pm
paul271
I found so much conflicting reports for the TD6 as to which coolant to use Craig. Did my mates TD5 last week and it was the red OAT coolant. The reason I finally opted for blue in mine was the guy in Auto save looked it up and it came up blue!!!
I shall listen to him no further!!!
Post #217629 19th Oct 2013 11:56pm
srpara
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Find the leak and as Cam-Tech-Graig Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down Bow down said then drain it out and put the pink in it Thumbs Up
Post #217630 20th Oct 2013 12:07am
Post #217632 20th Oct 2013 12:09am
Id'e go back to the man in Auto save and demand the right coolant (explaining to him what the blue will do to your head gasket) Unless they will pay for the head gasket when it goes wrong Whistle
Post #217633 20th Oct 2013 12:12am
paul271
Craig, what type do you normally put in as regards brand?
Post #217639 20th Oct 2013 1:23am
pld118
Welcome Paul,
Last week, I went to the LR main dealer to collect 1 litre of the same coolant they use (50/50 mix with water):
The MD uses Xpart, OAT5 Anti Freeze longlife (organic acid technology), Approved for MG Rover, picture of the bottle below:
Hope this assists Thumbs Up
Post #217640 20th Oct 2013 6:06am
I don't think there's a Pauline involved in this one.... Cool Discovery 4 HSE
1993 90 Tdi
Post #217646 20th Oct 2013 9:01am
Page 1 of 3 123>
