Home > Maintenance & Mods (L322) > Tailgate Headlining 'Loose'
pld118
Hi,
The headlining on our tailgate is just sticking out beneath the rubber seal (on the image you can just see the yellow foam edge of the headlining). It's not bad, all actually seems fairly secure and only about 12" is affected. Does anyone please know how I can 'clip it back in' or fix it?
Thanks
Post #218513 24th Oct 2013 6:17pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Mine is the same - was gonna get some double sided tape onto the edge but never got round to it.
Post #218527 24th Oct 2013 7:43pm
hongkongphooey
Isle Of Man
Mines exactly the same as that! I keep meaning to sort it out, a simple prodding back didn't work Cool Present* 2006 Santorini SC Vogue SE.
Gone* 2006 4.4 AJV8 Zermatt Vogue.
Gone* 2004 TD6 Bonatti Vogue.
Post #218538 24th Oct 2013 8:48pm
pld118
Main dealer was going to do it but said didn't have time as was a full headlining off and back on again which seems a bit OTT and if so... It's not that bad!
Post #218541 24th Oct 2013 9:21pm
There is a clip in the centre of the roof lining... just a couple of inches back from the rubber seal... It slides into a reciever bonded to the roof liner then that intern pushes into a hole in the roofskin Thumbs Up
They are made to pop open very very easily when the airbags deploy Thumbs Up
Post #218553 24th Oct 2013 11:04pm
pld118
Brilliant. Thanks Craig, will look later Thumbs Up
Post #218566 25th Oct 2013 6:32am
Thumbs Up Let me know if it works? Ill put the bill in the post sir Bow down Laughing
Post #218583 25th Oct 2013 8:43am
^ Laughing
Craigs new business, 'virtual tech help' Wink ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #218585 25th Oct 2013 8:50am
Thumbs Up every little helps... Thumbs Up Laughing
Post #218587 25th Oct 2013 8:54am
Cam-Tesco-Craig .... Whistle Whistle Laughing ====================================
Post #218652 25th Oct 2013 1:01pm
^^^ Thumbs Up Laughing Laughing Laughing Laughing Si. <This is my name.
Post #218656 25th Oct 2013 1:13pm
pld118
Ahem Embarassed so I located and unclipped the clip! There is a black plastic sheath attached to the inard of the headlining and I managed to free it from the white plastic clip that is fixed into the metal roof... There is no play forwards or backwards with the headlining. So how does the black sheath slid/ clip back onto the white clip please? Whistle
Post #218687 25th Oct 2013 3:09pm
pld118
Found this info by searching the forum re 'headlining' keyword:
"... Dan (Duckworths) sorted me a new clip [if your clip is broken].
In the centre its two parts - a metal U shaped piece with teeth and a plastic T shaped piece which attaches to the headlining. It really is a two minute job.
I removed the rubber tailgate seal first, then fit the new clip and pressed the headlining into place. The rubber tailgate seal then covers the edge of the headlining. "
http://www.fullfatrr.com/forum/topic15286....headlining
Post #218791 26th Oct 2013 6:33am
I have a similar problem and my clip is broken.
From what I can see the clip is a "push" / "thump" fit given there is no movement fore or aft.
It also seems that the headlining was glued in some way to the boot seal.
Some DIY needed to give more support, perhaps some small blocks with "sticky fixers" either side to provide more support either side of the fixing clip, and some decent contact adhesive around the boot seal, then support to hold all in place while it all dries. .
Post #218793 26th Oct 2013 6:55am
