![]() | Home > Technical (L322) > FBH |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
HI EVERYONE; it is getting to that time of year when the fbh will come into play ( or not as the case may be )!!!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35722 ![]() ![]() |
from the wiki,
HI STAN? thanks for the reply. but does that reply refer to my problem ? |
i have been looking at my post and wonder if there is a little confusion on my part as to what i am saying i have a problem with? i have the timed climate system showing on the nav screen and not the park heat ? whether that is something different? i dont know. |
it would appear that yours isnt firing because its not cold enough... ... - .- -.
THANKS for yours replies . perhaps it is simply due to the temp still? i remember last year it would fire during the warmer months, then i just left it and it started when i tried it in nov/dec;;.
it appears below 5c is the switch on point and the ticking noise is probably the fuel pump pumping to the fbh..
hi stan ok thanks for that. yes i remember the ticking noise but i could not remember if i only heard it when the burner was bieng used in any form or whether it was always there? so i guess it was as you say when the burner is running or about to fire up etc.
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I had a red led appear this morning in my way to work. I haven't activated mine yet so what's the Led for? |
the fbh should come on automatically when you start the range or it'll come on via the timer..
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
Just remembered.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
What I understand with mine (2007 TDV8) is the following:
Oh well, at least we have a fair number of differing theories to choose from some of which may even be right.... |
WELL i dont know what to think now. whether to wait until its 5c and below to see if it comes on or accept there is a problem if it is not starting upon reaching 16c. im sure that is the figure stated in the handbook?
