Home > Technical (L322) > FBH
The FBH fuel pump is located in an "inaccessible" region of the rear sub-frame on the right hand side, above the upper suspension in line with the drive shaft.
See here:
This is with the subframe dropped, you can't really see it from this angle when subframe up tight.
Am guessing it will only tick if conditions to run the FBH are right .
Post #221561 8th Nov 2013 12:19am
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
Activate at 5degC automatically?.
Mine activates when it's indicating 8degC or less [MY2006].
Do not have the options via MOST.
Post #221567 8th Nov 2013 6:21am
Prop
I think the TD6 and TDV8's may have different activation temps. My TD6 always activated when the temp was 8c or less but my TDV8 FBH does not seem to activate untill the temps drop to around 5c.
Post #221611 8th Nov 2013 10:03am
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
hi guys
just thought i would bring you up to date regarding my FBH not working.
living in the dordogne, we have sometimes to wait for the temp to come down at this time of year; but yesterday when i got up in the morning it was 5 degrees according to the temp sensor in the RR. so i set the heater to come on in 5 mins. and watched with baited breath. BUMHOLES Censored Censored Censored Censored Censored i said to myself when the start time came and went by without so much of a tick from the fuel pump.
this morning i awoke and at 10am the sensor was still showing 4.5 degrees. so i again set the heater to come on at 10.15; and locked the car up and went back indoors. i forgot all about it and stuck my head out the door at 10;30, and yes you have guessed it, Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter it was whining away and the pump ticking away so thank Censored for that.
so all my worries that it had suddenly packed up have all gone away, and obviously it will not come on unless the temp is actually BELOW 5c. it must be very precise with not working at 5c but working at .5 of a degree lower.
so im a happy bunny so thank you all for your help and advice that you have given regarding my earlier post.
thanks guys.
kind regards
bob
Post #223396 16th Nov 2013 7:36pm
now you can relax and drink that wine Bob.. Thumbs Up ... - .- -.
Post #223409 16th Nov 2013 8:47pm
BOBCUSSEN
hi stan, thanks for the reply. yes indeed. im actually looking forward to the winter now, especially when i walk outside in the mornings with a gleaming black Rover sitting in the drive with a pile of melting snow around it ( but not on it ) Bow down Bow down Bow down Bow down Bow down
thanks for you comments and help stan
kind regards
bob
Post #223410 16th Nov 2013 8:51pm
you're welcome.. Thumbs Up ... - .- -.
Post #223411 16th Nov 2013 8:52pm
73vse
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
As a newbie to these things ..... Does the FBh use much battery power ? Don't want to use it if I then find it's drained the battery for engine start up
Post #234246 12th Jan 2014 10:31am
on a fully charged healthy battery it will be ok...
Post #234267 12th Jan 2014 11:38am
