![]() | Home > Technical (L322) > FBH |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
The FBH fuel pump is located in an "inaccessible" region of the rear sub-frame on the right hand side, above the upper suspension in line with the drive shaft.
| Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675
I think the TD6 and TDV8's may have different activation temps. My TD6 always activated when the temp was 8c or less but my TDV8 FBH does not seem to activate untill the temps drop to around 5c. |
| BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296
hi guys
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
now you can relax and drink that wine Bob.. |
hi stan, thanks for the reply. yes indeed. im actually looking forward to the winter now, especially when i walk outside in the mornings with a gleaming black Rover sitting in the drive with a pile of melting snow around it ( but not on it ) |
you're welcome.. |
| 73vse Member Since: 27 Dec 2013 Location: North Yorkshire Posts: 97
As a newbie to these things ..... Does the FBh use much battery power ? Don't want to use it if I then find it's drained the battery for engine start up |
on a fully charged healthy battery it will be ok... |
| All times are GMT |
