Home > Technical (L322) > FBH |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
HI EVERYONE; it is getting to that time of year when the fbh will come into play ( or not as the case may be )!!!!
4th Nov 2013 7:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
from the wiki,
4th Nov 2013 7:06pm |
HI STAN? thanks for the reply. but does that reply refer to my problem ? , my problem seems to be that after i set the timer on the nav screen and press ok, the orange light comes on indicating it is in timer mode and after the other systems close down this light goes out. normally as i recall, when the time came for it to start, the light would come on and start to flash as it was firing up.
4th Nov 2013 7:37pm |
i have been looking at my post and wonder if there is a little confusion on my part as to what i am saying i have a problem with? i have the timed climate system showing on the nav screen and not the park heat ? whether that is something different? i dont know. |
4th Nov 2013 7:53pm |
it would appear that yours isnt firing because its not cold enough... ... - .- -.
4th Nov 2013 8:43pm |
THANKS for yours replies . perhaps it is simply due to the temp still? i remember last year it would fire during the warmer months, then i just left it and it started when i tried it in nov/dec;;.
4th Nov 2013 11:35pm |
it appears below 5c is the switch on point and the ticking noise is probably the fuel pump pumping to the fbh..
5th Nov 2013 9:29am |
hi stan ok thanks for that. yes i remember the ticking noise but i could not remember if i only heard it when the burner was bieng used in any form or whether it was always there? so i guess it was as you say when the burner is running or about to fire up etc.
5th Nov 2013 9:45am |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I had a red led appear this morning in my way to work. I haven't activated mine yet so what's the Led for? |
5th Nov 2013 10:19am |
the fbh should come on automatically when you start the range or it'll come on via the timer..
5th Nov 2013 10:23am |
Just remembered.
6th Nov 2013 6:45pm |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 |
What I understand with mine (2007 TDV8) is the following:
6th Nov 2013 7:35pm |
Oh well, at least we have a fair number of differing theories to choose from some of which may even be right.... There is nothing that can't be fixed with a hammer๐๐
6th Nov 2013 8:23pm |
WELL i dont know what to think now. whether to wait until its 5c and below to see if it comes on or accept there is a problem if it is not starting upon reaching 16c. im sure that is the figure stated in the handbook?
7th Nov 2013 11:53pm |
