Home > Maintenance & Mods (L322) > stuck cup holder
fil b
England 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
stuck cup holder
hi all, I have range rover vogue with a cup holder that is stuck in (2003) any ideas .
Post #223621 18th Nov 2013 10:25am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
If its the passenger one then the spring has snapped/gone. Easy to remove by taking the end panel off and undoing one bolt - will just slide out. Very expensive new, but I found one through one of the miriade of used parts websites for £10. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #223629 18th Nov 2013 12:17pm
greasemonkey1
United Kingdom 2005 Range Rover Vogue Td6 Java Black
copy and paste this link and you'll see everything on removal and re fitting of them annoying cup holders...http://www.youtube.com/watch?v=3stONqcWG5w
steve
Post #223647 18th Nov 2013 1:27pm
andy180
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I just bought a new one £80 from Powerful UK easy to fit takes 10 minutes Thumbs Up Never used it since but I hate having broken bits in a car Now: BMW 640d M Sport, Alpine White
Gone: Range Rover 4.4 V8 Vogue, Zambezi Silver, Charcoal Oxford Leather
Also: Mk1 Audi TT 1.8T Quattro, Brilliant Black
[URL=]
[/URL]
Post #223776 18th Nov 2013 10:35pm
daveo
they can warp from the heat and stick, if its that and the spring is intact it can be fixed, well i have done about 6 or 7 now... V8 facelift Range Rover Autobiography 22" wheels.
Post #223783 18th Nov 2013 10:48pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Mine was warped slighty and would not slide, I took the hole unit off and thinking it was the spring, it was ok but was the plastic bits that slide out for the cup extention part had broke. a bit af repair work and some filing down the sliding mechanism and now works a treat.
Word of warning, the plastic where the spring locates is very brittle and so is the spring tab ends, I broke one end off on the spring putting it back together but made a larger locating tab out of some spare plastic bits to stop it falling out when the spring is at full extention, ie cup holder closed.
Easy to repair, just watch that superglue and fingers....... Whistle If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #223987 19th Nov 2013 9:04pm
johnboyairey
mine was broken and full of hot chocolate when I bought it. I tried and tried to fix it. spring mout broken, it now works but doesn't pop out, so if I put a small knob on it, it will pull out, this is easier than pulling £80 out of wallet. looking out for a small knob. hee-he!
Post #224012 19th Nov 2013 11:11pm
666tur
United Kingdom 2012 Range Rover Vogue SE TDV8 Zambezi Silver
Same issue. Have removed and dismantled but struggling to put back together. Nothing seems to have broken.
I can't work out how to re-sit the spring.
Any advice on reassembly ? 2012 4.4TDV8 VSE
2004 TD6 132k miles- SOLD
1995 Land Rover Defender 110 Tithonus Ex Military
1995 Land Rover Discovery 3.9i V8 manual
Post #259028 12th May 2014 6:53pm
666tur
Specifically this brass spring loaded cylinder.
Thanks
 2012 4.4TDV8 VSE
Post #259035 12th May 2014 7:09pm
666tur
Actually I am now think this little cog should be spring loaded, driving the holder out when tension released and tensioned by being pushed back in. Anyone able to shed some light?
 2012 4.4TDV8 VSE
Post #259049 12th May 2014 7:32pm
The cog goes in the cog sized hole and runs on the teeth inside Thumbs Up Thumbs Up Thumbs Up
Post #259064 12th May 2014 8:34pm
666tur
Worked it out then snapped the little tips on the edge of the barrel spring so it does nt hold now! Looks like I need a new one. 2012 4.4TDV8 VSE
Post #259067 12th May 2014 8:40pm
Oooops Embarassed
Post #259068 12th May 2014 8:42pm
666tur
Gutted. Will see if I can get a used one as I now know how they work!! 2012 4.4TDV8 VSE
Post #259080 12th May 2014 9:24pm
