Home > Maintenance & Mods (L322) > stuck cup holder |
fil b Member Since: 08 Nov 2013 Location: poole Posts: 14 |
hi all, I have range rover vogue with a cup holder that is stuck in (2003) any ideas . |
18th Nov 2013 10:25am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
If its the passenger one then the spring has snapped/gone. Easy to remove by taking the end panel off and undoing one bolt - will just slide out. Very expensive new, but I found one through one of the miriade of used parts websites for £10. Current Fleet:-
18th Nov 2013 12:17pm |
andy180 Member Since: 26 Aug 2010 Location: scotland Posts: 509 |
I just bought a new one £80 from Powerful UK easy to fit takes 10 minutes Never used it since but I hate having broken bits in a car Now: BMW 640d M Sport, Alpine White
18th Nov 2013 10:35pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
they can warp from the heat and stick, if its that and the spring is intact it can be fixed, well i have done about 6 or 7 now... V8 facelift Range Rover Autobiography 22" wheels.
18th Nov 2013 10:48pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Mine was warped slighty and would not slide, I took the hole unit off and thinking it was the spring, it was ok but was the plastic bits that slide out for the cup extention part had broke. a bit af repair work and some filing down the sliding mechanism and now works a treat.
19th Nov 2013 9:04pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2026 |
mine was broken and full of hot chocolate when I bought it. I tried and tried to fix it. spring mout broken, it now works but doesn't pop out, so if I put a small knob on it, it will pull out, this is easier than pulling £80 out of wallet. looking out for a small knob. hee-he! |
19th Nov 2013 11:11pm |
666tur Member Since: 15 Feb 2013 Location: Nottingham Posts: 108 |
12th May 2014 6:53pm |
Specifically this brass spring loaded cylinder.
12th May 2014 7:09pm |
Actually I am now think this little cog should be spring loaded, driving the holder out when tension released and tensioned by being pushed back in. Anyone able to shed some light?
12th May 2014 7:32pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
The cog goes in the cog sized hole and runs on the teeth inside |
12th May 2014 8:34pm |
Worked it out then snapped the little tips on the edge of the barrel spring so it does nt hold now! Looks like I need a new one. 2012 4.4TDV8 VSE
12th May 2014 8:40pm |
Oooops |
12th May 2014 8:42pm |
Gutted. Will see if I can get a used one as I now know how they work!! 2012 4.4TDV8 VSE
12th May 2014 9:24pm |
